TheNewbie Posted December 26, 2011 Report Share Posted December 26, 2011 Alright soooo, i got a MRP-1000 alpine amp to go along with a DC level three, It worked then stopped, worked then stopped, couldn't find the problem. Recently it stopped again, doesn't seem to go into protect and it went off when i turned the music down.. I assumed it was the wiring, so i bought 4 gauge Knu wires. Ran the whole setup got that in. Tried it again still isn't working.. I know it's not the woofer because i have another speaker i tried to hook up to it. I opened up the amp to see if i could see anything shorted couldn't see anything. Could anything else cause this? Going to pick up a DMM soon, if not tonight if someone would be willing to walk me through how to see if it's putting output. I also receieved a dd-1 wooohooo :)Thanks. Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes. Link to comment Share on other sites More sharing options...
Freshman6969 Posted December 26, 2011 Report Share Posted December 26, 2011 check the ground Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
TeamHT Posted December 26, 2011 Report Share Posted December 26, 2011 Just so you know, almost ALL amps are stupid. They only do exactly what we tell them to do whether it is right or not. What is the voicecoil configuration of the sub? What is your ground like? Tell me...does this smell like chloroform to you? Link to comment Share on other sites More sharing options...
One Way Posted December 26, 2011 Report Share Posted December 26, 2011 Have you checked your ground? Where is it located at? T-line build- http://www.stevemead...e-t-line-build/ Link to comment Share on other sites More sharing options...
TheNewbie Posted December 26, 2011 Author Report Share Posted December 26, 2011 Just double checked the ground it's solid, it's a 4 dvc sub. Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes. Link to comment Share on other sites More sharing options...
TeamHT Posted December 26, 2011 Report Share Posted December 26, 2011 What is solid...as in it is not moving anywhere? Tell me...does this smell like chloroform to you? Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted December 26, 2011 Report Share Posted December 26, 2011 Just so you know, almost ALL amps are stupid. They only do exactly what we tell them to do whether it is right or not. What is the voicecoil configuration of the sub? What is your ground like? Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
TheNewbie Posted December 26, 2011 Author Report Share Posted December 26, 2011 What is solid...as in it is not moving anywhere? Yes, and the paint is scrapped off so it's just metal. Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes. Link to comment Share on other sites More sharing options...
TeamHT Posted December 26, 2011 Report Share Posted December 26, 2011 Where? Tell me...does this smell like chloroform to you? Link to comment Share on other sites More sharing options...
TheNewbie Posted December 26, 2011 Author Report Share Posted December 26, 2011 In back of the car, guess it would be right by my spare it's hooked up on a bolt to metal. Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes. Link to comment Share on other sites More sharing options...
