Okay so I finally hooked up my sundown sax1200d just to test it and see if it works. my sub is wired at 4ohms and I wired everything to the amp but it takes over half gain to just make my sub move at all. Sundown Z v.2 sub and yes i know it only puts out 360 watts at 4ohms but it still should be enough to at least sound decent. My settings on amp were: Gain over half way, Subsonic 20, LPF 80, Bass boost 0, Phase 0, and I did not have the bass knob plugged in. Headunit settings are: LPF 80 and sub setting on 0, bass boost 0, sla 4, My regular EQ, and HPF 80. This sub would hit like no other with my kenwood 500wattrms amp at 4ohms. When i plug the sundown in, it takes over half gain just to move the sub at all.
PSI and Sundown audio FTW!! 2001 F150 crewcab Sundown z12v.2 on a sax1200d! 1/0 welding wire!
Your sub setting should be at max on your headunit.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
Posted (edited)
you are also only running a 4 ohm load so it is not getting very much power ....wire it to 2 or 1 ohm and it should move just fine
Edited by extremeauto
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
Yeah i know this is true but I had it on a 250 watt rockford amp at one time and it moved just fine. Now it takes 1/2 gain or more just to even move the sub at all.
yeah, my headunit is pioneer 3200ub. and phase is at 0 on amp. Sub sounded fine with my kenwood 500wattrms and rockford 250wattrms. I just figured i would plug in the sax1200d just to make sure everything works fine before i change impedance to 1ohm. After I got everything in, just my door speakers would play bass until i got to half gain and then sub comes in. It is very very weak even at 1/2 gain.
  • Who's Online   0 Members, 0 Anonymous, 2628 Guests (See full list)
