n8ball2013 Posted December 27, 2011 Report Posted December 27, 2011 just looked it up does it say monsoon on the factory radio? THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
IKnowImLost224 Posted December 27, 2011 Author Report Posted December 27, 2011 I believe the grills on the doors have monsoon on them. If that's the case then no
ALPINE408 Posted December 27, 2011 Report Posted December 27, 2011 it says in the book with aftermarket head units if the rca voltage is above 2 volts it will cause distortion and there is a imput knob you can adjust to get rid of it have you tryed that yet??????????? Have you ever had your woofers blown?
IKnowImLost224 Posted December 27, 2011 Author Report Posted December 27, 2011 i just read the manuel it says there is a knob for imput level to adjust if your getting distortion from high output lvl decks greater than 2 volts With the adjustment turned all the way down, halfway, or all the way up distortion is still the same. Only thing that changes is how loud the music will get
n8ball2013 Posted December 27, 2011 Report Posted December 27, 2011 crutchfield says you need a GM VT-GMRC-01 not what you have. and that makes sense becuase you do not have any rca connections on your factory head unit or an ampo THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
ALPINE408 Posted December 27, 2011 Report Posted December 27, 2011 crutchfield says you need a GM VT-GMRC-01 not what you have. and that makes sense becuase you do not have any rca connections on your factory head unit or an ampo ouch hope you can return it Have you ever had your woofers blown?
IKnowImLost224 Posted December 27, 2011 Author Report Posted December 27, 2011 crutchfield says you need a GM VT-GMRC-01 not what you have. and that makes sense becuase you do not have any rca connections on your factory head unit or an ampo But what would the factory h/u have to do with the RCA's on the GMOS? The GMOS is for installing an aftermarket radio
ALPINE408 Posted December 27, 2011 Report Posted December 27, 2011 http://www.crutchfield.com/S-EHin4IbpW15/p_120GMRC01/GM-Factory-Integration-Adapter.html do you have an amp a factory amp i dont understand why you need rca outputs if you have no amp? Have you ever had your woofers blown?
n8ball2013 Posted December 27, 2011 Report Posted December 27, 2011 If it does not have monsoon you do not have a factory amp. If you are trying to add an amp you are doing it way wrong. If you can't grasp this take it to a shop please you're going to burn the car to the ground. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
