DC Sound Lab
Well, I have pretty bad luck.
I think I have coil rub in my New level 5.
I push down dead center and I get no rub, but if I move just a fraction of a centimeter, I can feel/ hear rub...
Subs are D1.
Both coils read 1.0 - 1.1, but changes once in a while.
On my other sub I think I blew has some coil rub only when you push lightly in the middle, has both coils reading 1.0 - 1.1
The funny thing is that it doesn't have any coil rub when pushing down evenly on the sides but has some rub periodically.
Im SOL right now.
Its hard to tell if the subs are in need of a recone or am I just imagining things.
I have a vid of the used sub and trying to diagnose it.
Help me please SMD.
Vid of used sub, not the new one.
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
If its rubbing its most likely blown, Both my dual 1s sit in about the same ohm area, And i believe the ohm load will always change when you move the coil.
Edited by LoudNLow931
2008 Dodge Ram 2500 6.7l Cummins
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
Audio Technix Wiring & Sound Deadener
My Youtube
Feedback
My xls did the same thing.... as long as it plays don't worry about it... it could be the former is dimpled slightley and hitting the pole.... how much power are you running to them and what size enclosure.... over excursion can dimple former
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I have similar prob. It was on an re sx10. If you push on dead center no rubb, if you go in any direction slightly then there is coil rubb.. but it plays and hits like nothing wrong. Only thing I could think of was, I bought this sub from a friend who made his own box for it and it was like less than 1^3ft. and had some jimmie riggd pvc port to no specs.. maybe bad air space/tuning caused it?!?
2008 TBSS Black Granite
Alpine CDA-117
Clarion EQS746
AudioQue Supertweets @ dash
Alpine DDT-s30 @ b pillars
Alpine SPR-60c @ front doors
Alpine SPR-60 @ rear doors
Alpine PDX-f4
Second Skin DampPro
KNUkonceptz Wiring
DCpower 270amp alt
Optima YT underhood *temp
Two15DCxls
Hifonics bxi2610 *temp
saz4500 and 4 xp3000s coming soon.
When I lift up on the used sub, it rubs alittle.
And I'm running one SD8K @ 1 ohm.
Do you think the newer sub is blown if it rubs only from the side kinda in the center?
Not dead center but kinda off the center...
It'd hard to explain
HMU!!!
95 Bonneville SSE
yep.
i think they are ok... :pardon:
if u push on the side of the cone itll probably rub, the lvl 5 has a fairly tight gap already.
Edited by matt402
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
If you push dead center on the cone and you have now rub then u are good. If the coils still read properly then you are good. Don't forget to touch the leads on your dmm together to check the resistance. Subtract that number from the reading you get on the coils.
If you press down off center of the sub, you can cause coil rub.
TThanks everyone for replying!
I was reading through the comments,
Tomoro ill check the resistence once again after I touch the ends together.
On the used sub, I get coil rub when I barely press down dead center...
But once I press really hard I won't get it till it cone back to the "rest" point.
On the new sub, I don't get rub if I press down dead center, but if I move slightly off the center, I mean just a fraction, I get rub.
I accidentally broke the dustcap of the old red dc sub while pushing down in the center.
HMU!!!
95 Bonneville SSE
You do have the possibility that the former could have gotten bent just a little and could be rubbing the pole, or if the coil is starting to come unwound due to high heat from extreme clipping, that could cause the rubbing sound.
