Second Guessing My Electrical
Can you fit more batts in the back? Or bigger ones? Id do 4 runs of 0g front to back 2 pos 2 neg....
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Already got the 4 runs. I could MAYBE fit another 6500 in the spare tire well. Would 3 3100's be a huge improvement over the 6500's?
SMD Super Seller
My Feedback Thread
3100s are beast.... I had 2 3100s and 2 3400s on 10k they held up well
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
3100s are amazing, but i got pretty bad drop with 2 dc 5ks.... with a 270 and basically 3 3100s and a yellow top in front....
i can drop to 12v full tilt but thats after about 1-3 min of playin time
i think u will be allright as long as you watch the voltage
but yes more batteries are always better so if you can fit them do it i would like at least 2 more group 31s or xs3100s,
ur question about which would be better, honestly Nathan is prolly the only one who can answer that to a point if its cheaper to go with the 6500 why not just get 1 or 2 more of thoes instead of spending 1300 on batteries
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
have you ordered the 8s and the dc1.2k ? if not switch that for batts ? just an option ?.. but being at 12volts isnt that bad... everything should survive.
  • Who's Online   1 Member, 0 Anonymous, 1361 Guests (See full list)
