Help me build my first sound system.
I have never had a sound system before and I want to build my first system. I listen to Hard rock, heavy metal, and anything with extreme bass. I only want to spend around 350 on it. Here are somethings I have picked out and tell me of they will work together and if you know better deals in my price range tell me.
HeadUnit: http://www.walmart.com/ip/Pioneer-DXT-2369UB-Complete-Car/17242512
Subwoofers: http://www.walmart.com/ip/Boss-Audio-CX104DVC-CHAOS-EXXTREME-10-DVC-Subwoofer-Brushed-Injection-Cone-Double-Stacked-Magnets-Dual-4-Ohm-Voice-Coils-1200W/16829725?findingMethod=rr
Amp: http://www.sonicelectronix.com/item_33008_MB-Quart-FX1.600.html
I want to bridge TWO subs to that amp which i belive will make it 2 ohms and then the RMS will match.
______________________________EDIT__________________________----
i looked around on ebay and how does this setup look?
http://www.ebay.com/itm/2-Alpine-Type-R-12-Car-Subwoofers-plus-Box-/130624455128?pt=Car_Subwoofers_Enclosures&hash=item1e69d301d8#ht_500wt_950
http://www.ebay.com/itm/Lanzar-HTG257-2000-Watt-Peak-500-Watt-RMS-2-Channel-Bridgeable-Amplifier-Car-Amp-/350509870058?pt=Car_Amplifiers&hash=item519c042bea#ht_3347wt_1101
Edited by jhboy10
check out craigslist for some equiptment, you can sometimes find steals there, otherwise pick you up a single skar audio 12 or and SA-12 those will be louder than two boss subs, grab a decent amp, perhaps the one you already picked, remember wire is not cheap either knukonceptz has good cheap wire tho.
if i were you, i would stay away from boss car audio, for cheap subs that are fairly decent i would do this
http://www.audiosavings.com/products/12-Inch-Car-Subwoofer/Pair-of-Hifonics-HFX12D4-HF-Series-12-800-Watt-DVC-4-Ohm-Car-Subwoofers-Bundle/%282%29+HFX12D4.aspx
One of the best subs on a budget, look into those for the price, you will damn need push them full tilt, in the right enclosure they will meet your demands.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
try and up it to 500!then go with
Skar vvx12, Sundown sa12, or Alpine type r 12 (Dual 4ohm)
just use the amp you had picked out
KnuKonceptz cca would prolly be alright for you
A cheap alpine or pioneer headunit with parametric eq
A set of 6.5 components with high sensitivity to run off the headunit if your not running a speaker amp.
All that can be found in classifieds at very reasonable prices. My first system was decent but i wanted more and ended up losing money by selling it to pay for my better system. Do it right the first time! :drinks::santa:
PSI and Sundown audio FTW!! 2001 F150 crewcab Sundown z12v.2 on a sax1200d! 1/0 welding wire!
  • Who's Online   0 Members, 0 Anonymous, 1363 Guests (See full list)
