problems
kidd666
So recently my amp has started to make a bunch of noise come out of my subs. I have disconnected the RCA cables and it will still make the noise. I'm thinking it has something to do with the rem wire. But I'm not quite sure what it is. Any advice would be greatly appreciated. And if I can tomorrow or tonight if they do it again I'll shoot a video of it.
Not sure exact problem but would doubt the remote wire could cause anything. To be sure, next time it does it use a DMM (Digital Multi Meter) on the amp and make sure the power and remote both have 12+ volts going to them. Also i would check my ground wire to make sure it has a good connection with bare metal.
Current Set-Up
2004 Chevy Tahoe
Subs: 2 DC XL 15's
Box: 8.5 ft^3 @ 38hz
Amp: Amrican Bass VFL 500.1
Alt: Db Electric 250amp
Batts: 2 Kinetic HC 1200s
Radio: Pioneer 3300UB
Doors: Pyle Pro Mids/Goldwood Tweets
Amp: Alpine MRP-300/Hifonics ZX80.4
Wire: Kicker 1/0 Guage
Termlab: 153.1 Outlaw Style @ 46HZ
ground noise maybe. change out the grounds to better ones.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
x2, do this and then post back.
2005 VW GTI 1.8T
(4) Fi BTL N2 15s/ 4th order bandpass
(2) Crescendo BC5500s
Crescendo c1000.4
(4) Selenium 6w4p (Q logic Kicks)
Crescendo FT1 tweeters
3 runs of 4/0
Too much 1/0
DC power Engineering 320 XP ~235A at idle
3 XS D3100s
ok so i remounted my ground. heres some pics so you can see.
the subs still make the noise every now and then mainly when im on the freeway going over road bumps at fas speeds. and the subs have always thumped when they turn on since ive had this amp. i still dont know whats going on and would still appriciate some advice
Did u run the power, rca's, remote and all that on the same side of the car? Some people say that it won't effect anything, but from personal experience, it definately does.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
no i didnt i have my rcas and remote wire runing down the drivers side and power down the pass. i have put my dmm to it and got over 12 volts to power and remote wires. the amp chooses when to turn on and when not to. could this probably be a problem with the amp itself?
power wire
remote
Edited by kidd666
By chance do you have a pioneer head unit?
Current Set-Up
2004 Chevy Tahoe
Subs: 2 DC XL 15's
No it doesnt
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   1 Member, 0 Anonymous, 600 Guests (See full list)
