OK for one you had a shop do it. That means you don't know what you are doing.second rcas are shielded mow. Back in the day they weremt.that's where that rule came from. Don't buy shit product and you don't have to worry about it. I've done dozens of cars on the same side without issue
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
if i had a shop do it it dont mean i dont know how to do it, it was a choice i made and didnt want to go through the trouble of running multiple runs of 1/0 gauge and take apart my interior to install the dynomat, had a few hours and had to get it done cause i had to do other things and would have taken me ages to do it, and i have another post where i say im never taking it back to a shop and will do things myself since theey screwed up on my grounds holding 2 wires together with zip ties and tape
edit: i did the install with no engine noise, now i have to check my ground to check if they are bad. most likely i don't have a good ground
Edited by Miguels
I would try and find an amp to test In place of yours. If it plays fine you know you have a bad amp.
Current Set-Up
2004 Chevy Tahoe
Subs: 2 DC XL 15's
Box: 8.5 ft^3 @ 38hz
Amp: Amrican Bass VFL 500.1
Alt: Db Electric 250amp
Batts: 2 Kinetic HC 1200s
Radio: Pioneer 3300UB
Doors: Pyle Pro Mids/Goldwood Tweets
Amp: Alpine MRP-300/Hifonics ZX80.4
Wire: Kicker 1/0 Guage
Termlab: 153.1 Outlaw Style @ 46HZ
So it turns out its the amp. tried a dual 4 channel in place and turned on fine and was putting out sound so im in the process of sending the amp to the warrenty company now
Glad you found the problem.
Current Set-Up
2004 Chevy Tahoe
Subs: 2 DC XL 15's
