Audiocontrol DQX
Product Features
AudioControl DQX Digital Car Audio Equalizer and Crossover
30 Bands of constant-Q equalization to enhance sound quality
Dual, fully adjustable parametric equalizers allow you to select a center frequency, dial in the ideal bandwidth and apply the appropiate amount of boost or cut
3-way 24dB/octave electronic crossover allows you to configure to almost any high performance mobile audio system
Non-volatile memories provides 8 different system settings
24 Bit digital signal processing ensures maximum sound quality
Bright and Dim settings for display
1-year SonicElectronix.com warranty
Products Specifications
Maximum input level: 7.5V RMS
Maximum output level: 7.5V RMS
Output gain: 10dB
Frequency response: 10-22,000 Hz
Total harmonic distortion: 0.01%
Signal-to-Noise ratio: 105dB
Balanced input noise rejection: 60dB
Input impedance: 20,000 ohms
Output impedance: 150 ohms
Crossover slope: 24dB/Octave
Crossover type: 3-way Linkwitz-Riley
Equalization boost/cut: 12dB
Power Supply: High headroom PWM switching
Fuse rating: 2 amp
Dimensions: 7"L x 10"W x 1-1/4"H
sat most of the time I've had it aquired a couple of scratches by doing so 250 shipped would be nice but ill take the best offer i get only trades would be sundown sa12 d4s, powerbass xta 5k, HO ad244 alt, 100 ft of 0 gauge, deadener, ss mlv, pioneer CD-ID100I +cash either way depending what you have
How high can the PFM and lo/mid crossover points be set? Can pfm be set at 100 and lo/mid at 300ish?
not sure I never had time to set it up to use it as a crossover only used it as a line driver when i burped for state finals,looking for your answer as we speak
pfm should be set at the f3 of your enclosure should be should be substantially lower as with lo/mid but each to their own it should do it
That's irrelevant to the application i'm considering this for. I'm wondering if it would work for my 3-way front stage. Midbass 100-300hz, midrange 300-3500hz, and tweets 3500 and up. Subs wouldn't be run through this. It doesn't say in the manual about the pfm, but I don't think the 300hz xover point would be a problem.
SMD Super Seller
My Feedback Thread
gotcha now should work great
I have the same EQ except w/ the DDC add-on controller. Works awesome. You have seperate inputs for frt, rear & subs. Then you have 10 bands each. So staging shouldn't be a problem.
TEAM Fi CAR AUDIO/ TEAM CRESCENDO AUDIO
Bagged '06 Dodge Magnum R/T "WICKED WAYS"
-4 Fi SP4 18's (4th Order)
-2 Fi SSD 10's (midbass)
-4 Diamond Audio D6 Comp Sets
-1pr. Crescendo FT-1 Supertweets
-Dual Alts -6 XS Power Batts
-4 Crescendo BC3500d's (subs)
-1 Crescendo BC2000d (10's)
-1 Crescendo c1100.4 (comps)
