DC Sound Lab
The box is for two DC XL 18's in a forester on a Skar 4.5k
Edited by stanbro
Build v1 15" Skar VVX (custom ported box) w/1.2k Sundown ampBuild v2 18" DC XL x2 (custom ported box) w/4.5k Skar amp
Build v3.3 destruction and re-construction time!
I would double layer the baffle...subs facing back/port to side? Looks like it should waaaang
'94 Ford Ranger Ext. Cab
(3) DC XL 15's, check that (3) 18's this year!
(2) DC 5k's
(6) XS Power D1600's
158.9.......so far......
Montana DC Dealer/State Rep.
I don't have any experience with DC subs but the box looks good, you may want to brace side to side as well, wouldn't hurt, but good looking box
2011 Mitsubishi Outlander
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Transmission line enclosure
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
I think conceptually looks fine, I can't speak to what the dc subs like tho. But good first design if its your first.
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
Subs up port back
not the first I've built but first I've tried to due up on my own from scratch
Double up the baffle and might need bracing in the port also. Looks good tho
www.dcsoundlab.comDCforum.jpgyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3
SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO
on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator :)
unless im looking at this wrong..the port is 28 long on the side that is 31 long correct? if so id make so the end of the port is the width of the port away from the back of the box...if that makes sense
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
you looking at width.. the port runs length wise.. gap is 4.5" so lost an inch. I was trying to keep the area directly bellow the woofers a consistent flat surface. no sure if it really matters though
level the subs and that would help to keep a consistant flat plus you get to havr the port at back
  • Who's Online   0 Members, 0 Anonymous, 5403 Guests (See full list)
