lagexe Posted January 4, 2012 Report Share Posted January 4, 2012 I know, I know, most in this forum don't like caps. At least from what I've read that is the Majority Opinion. However, at the moment I can't afford a new alternator I already went $200 of my budget when building the new system. Also, I have heard that caps burn out an alt faster. This is not a problem since I have a life time warranty (on my third in 5 years time). Is the pic below how I should wire the caps? When I get taxes I will be getting a new alt, and maybe another battery if needed. Baby steps... Quote Link to comment Share on other sites More sharing options...
Emoxihax Posted January 4, 2012 Report Share Posted January 4, 2012 question: How to wire 2 caps answer: you don't Quote 2004 Volkswagen GLI 1 10" Skar VVX ^^^ Looking for an amp to run it, Pm me if you have one ^^^ Link to comment Share on other sites More sharing options...
lagexe Posted January 4, 2012 Author Report Share Posted January 4, 2012 (edited) question: How to wire 2 caps answer: you don't I'm new to this, do you mind explaining a little more. You've told me what not to do (kinda), you forgot to tell me what to do. No sarcasm intended. EDIT: I appreciate you helping. Edited January 4, 2012 by lagexe Quote Link to comment Share on other sites More sharing options...
ALPINE408 Posted January 4, 2012 Report Share Posted January 4, 2012 just put them in parallel next to each other + to + then - to - then to your amps if you must use caps Quote Have you ever had your woofers blown? Link to comment Share on other sites More sharing options...
C-Fizzy Posted January 4, 2012 Report Share Posted January 4, 2012 Caps will do more harm then good when you have voltage drop. Don't do it. Quote under construction I hate People with crappy primered cars rolling on hubcaps that are louder then me. u hate c-fizzy? Link to comment Share on other sites More sharing options...
lagexe Posted January 4, 2012 Author Report Share Posted January 4, 2012 (edited) just put them in parallel next to each other + to + then - to - then to your amps if you must use caps I must for now, my alt is only 120amp (80 stock, I'm using one for a jeep 2 or 3 years newer than my jeep, because it's the only bigger one that will fit) and my lights dimmed pretty bad with my old sony 1200w-D. I'll draw another pic if you can tell me If I've understood you correctly. Edited January 4, 2012 by lagexe Quote Link to comment Share on other sites More sharing options...
techforce Posted January 4, 2012 Report Share Posted January 4, 2012 well, if you have to have caps, re: you already have them, wire them like you listed... BUT, I would move the caps close to the amps, ground the amps to the cap and ground the cap to the chassis... even a cheap walmart battery would be better than a cap, unless you are seeing some wicked voltage drop.... Quote Link to comment Share on other sites More sharing options...
splzx3 Posted January 4, 2012 Report Share Posted January 4, 2012 (edited) question: How to wire 2 caps answer: you don't ^like Edited January 4, 2012 by splzx3 Quote ________________________________________________________________________ deepsilencer, on 22 Aug 2011 - 17:32, said: splzx3, on 22 Aug 2011 - 17:27, said: i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD lol your mom is a G! WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum. Link to comment Share on other sites More sharing options...
ALPINE408 Posted January 4, 2012 Report Share Posted January 4, 2012 ive had systems were caps helped under 1200 watt systems caps do help anything over that they hurt i have tryed and tested this shit in joeys street max tropper doing 158 dbs we had to have a cap in there in order to keep the deck on for a second longer because street max is one batt and he had 4 7 ks on it Quote Have you ever had your woofers blown? Link to comment Share on other sites More sharing options...
techforce Posted January 4, 2012 Report Share Posted January 4, 2012 also keep in mind, this will strain the shit out of the alt in your setup, the caps will be steeling from the amps to recharge... A cap is good for if you have lets say a 300 amp alt and only draw 250 amps at full load and you are having voltage drop from the front to the back... but in your case it will prolly hurt you... Quote Link to comment Share on other sites More sharing options...
