Posted (edited)
On my Pioneer AVH-P4200DVD HU the subwoofer goes from negative 20 to positive 6. If I turn it up to 6, is that when I'll get the most power from the sub preout or will that be just like a bass boost.
Edited by onyx1silverado
Rockford Fosgate T5001 bd-cp
2 DC level 2 12's
Focal Access Components in the front
Focal Access Coax in the rear doors
Rockford Fosgate Punch Boosted Rail 4 channel rms 4x75
XS Power D3400 under the hood
Knuconceptz Ultra Fleks Power & Ground
That is when you'll get full rated voltage out of your preouts
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
I would have to say yes
2 DC level 2 12's
is it the same with the kenwood head units? mine goes from -15 to +15, where should I leave it when tuning with a DD-1?
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
  • 3 weeks later...
^^^why at zero instead of the h/u's max spot??...ive always wondered this
because if you use anything higher than 0 on this headunit you couldn't turn the volume up as much because the signal would clip/distort. You want the highest preout voltage possible so your amp amplifies the least.
At lower volumes, or with quieter music you could go into the + range, but not at max full tilt CLEAN volume
  • Who's Online   0 Members, 1 Anonymous (See full list)
