Relyks Posted January 6, 2012 Report Share Posted January 6, 2012 so i cant find a c clip on it and im lost on how it comes off.... any clues its a 05 Kia spectra with manual cranks Quote --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12 Link to comment Share on other sites More sharing options...
thecityxignites Posted January 6, 2012 Report Share Posted January 6, 2012 You have to get a window crank puller tool. http://m.summitracing.com/parts/WMR-W80646 ^^^like that one Quote 2001 chevy cavalier Rebuild in progress what happens when your CD player skips and you accidentally drop a 22 hz sine bomb at an unholy volume on 7-8 year old subs? Mechanical failure floppy sub knockage on at least 2. well...as i see the level 6 is compared to a lamborghini.....but a corvette? i was thinking more like a chevy volt. its cute and new and "hip", but i would just rather stick my dick in a blender......... Link to comment Share on other sites More sharing options...
Relyks Posted January 6, 2012 Author Report Share Posted January 6, 2012 but there is no clip in sight.... Quote --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12 Link to comment Share on other sites More sharing options...
thecityxignites Posted January 6, 2012 Report Share Posted January 6, 2012 You won't be able to see it, but it's there. I thought the same thing when I was taking the door panels out of my cavalier. That tool makes it easy. Your local autoparts store should have one. Quote 2001 chevy cavalier Rebuild in progress what happens when your CD player skips and you accidentally drop a 22 hz sine bomb at an unholy volume on 7-8 year old subs? Mechanical failure floppy sub knockage on at least 2. well...as i see the level 6 is compared to a lamborghini.....but a corvette? i was thinking more like a chevy volt. its cute and new and "hip", but i would just rather stick my dick in a blender......... Link to comment Share on other sites More sharing options...
Blue Posted January 6, 2012 Report Share Posted January 6, 2012 Wonder if it's like my sister's old neon, get a small towel and with the crank pointed down work the towel up to the part that goes in the door. lift up with a slight shimmy from side to side and pull the handle off. Might work Quote formerly known as Blue86f150 its a 4th order just because its tuned in the 40z doesnt mean it wont reach down and jiggle your balls at sub 30 hz frequencies. Regardless if they were dipped platinum and were stuffed in Beyonce's twat.....way too fucking exspensive this sux camel dicks Link to comment Share on other sites More sharing options...
kandiman71874 Posted January 6, 2012 Report Share Posted January 6, 2012 Trust me, the clip is there its just impossible to see like has already been said. Try Blues trick or go buy the tool. I have a 99 sephia which is the spectras prior model and its the same stupid ass style clip that has been on window cranks for many many years. Quote Daily Driver 1999 Kia Sephia Kenwood DNX-893s Audison Bit One Processor 2 Dat 4.125's Sundown Audio SCV-6k Hertz hsk-165xl's Mids running active Focal V30 Series Tweeters running active Sundown Sa-8 v1's in the doors 2 Sundown Zv5 12's Lots of Hushmat Big 3+ and 3 + & 3- runs of Trystar 2/0 2 Dc Power Engineering 320 HP Alts 2017 Comp Vehicle 2006 Toyota 4 Runner Kenwood Excelon DNX-893s Audison Bit One HD DSP 4 Sundown Sa 6.5v2 Component Sets Focal Access 6.5 2 ways Sundown Audio Sax-50.4 Sundown Audio Sax-100.4 2 Dc Power 370xp Northstar agm27f Northstar agm65 2 Northstar asmagm 480's 2 Dual 1 Sundown Nightshade v3 12's 2 Sundown SCV-7500's All SMD Fuse Holders Shitload Of Sundown 1/0 120 sq ft Second Skin Damp Pro No, Its Not A Burp Truck!!!! 2016 Season 3rd place in Xtreme 1 At Finals 2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations) 2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL David said: audio is a lifestyle, not a hobby newls1 I cant read a tape to save my life... 1/2's are ok, but other marks confuse me kingsuv only men who cant read a tape, take it in the ass kingsuv you sir, get a pink hard hat on jobsites Link to comment Share on other sites More sharing options...
Decaf Posted January 6, 2012 Report Share Posted January 6, 2012 clip is between handle and plastic washer. u take a flat head to separate handle and washer, push the panel in to create room at the crank spot with ur hand, and i use a headunit "key" bent slightly to push one side of the clip off. its enough that the handle comes off yet the clip stays attached to handle so u dont loose it currently my saturn has all panels off by that method while i deaden everything Quote Link to comment Share on other sites More sharing options...
Relyks Posted January 6, 2012 Author Report Share Posted January 6, 2012 you guys were right i went out and bought the tool worked it off very irritating pin. took forever to find once i found it on 1 door it was super easy to do the next tho thanks alot to all you guys Quote --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12 Link to comment Share on other sites More sharing options...
Relyks Posted January 7, 2012 Author Report Share Posted January 7, 2012 http://www.stevemeadedesigns.com/board/topic/130066-kia-spectre-05-install-done-pics-up/#entry1828736 check out the build you all helped me on (: and in the video you see where i got the handle off but i messed it up but i finally learned :/ Quote --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12 Link to comment Share on other sites More sharing options...
