So I have this design by PWK, now the problem is is that when I first requested it , I stated I had 33"w but soon after I received the blueprint noticed I only had 32.5w....I email him back and this is what he said to do to correct the problem " If you have to take an inch off the width, remove it from the width of the chambers. Take 0.5” from each rear chamber and 1” off the front chamber. Do not alter the vents." Now my question is, where do I do that at...I dont want to mess up this design so if you guys know how can you please tell me. This is the first 6th order Ill be building and want to build it right.
Edited by ChrisLun
2006 Dodge Charger
(2) Kinetic 3800
(1) DC Power 270XP
(4) T1-12D4
(1) T2500BDCP
(2) T400.4
7.5 cubic ft.
(2) 6 in ports thru the rear deck
(2) T165.2
(2) T169.3
Wanna start this build tomorrow....so bump
2006 Dodge Charger
(2) Kinetic 3800
(1) DC Power 270XP
(4) T1-12D4
(1) T2500BDCP
(2) T400.4
7.5 cubic ft.
(2) T165.2
(2) T169.3
It's late, kinda tired, but I think I understand what your're trying to do......simply subtract 1/2" from each of the panels that run width ways, that will leave the ports exactly the same.....just visualize removing 1/2" from the middle of each of those panels that run width ways, that'll give you that 1/2" back so the box will fit.
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
If I'm understanding this correctly, Off the top section you take off 1 inch. Then each of the bottom sections you take off .5 of an inch on each, preserving the ratio of the box but now it is with less box width now making it 32"
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
3 cube box 2 6" aeros
XS Power D2400 & Xp950
Skyhigh/Knukonceptz/Rockford Fosgate wiring
More Coming Soon.. Check my builds below.
97 Civic Hatch Build
86 Caprice Build
you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion
I'm on mobile right now so i can't see the pic too well but, Of the top section, If it says 26.5, It should now be 25.5 and each of the bottom sections say 12.875 i think, It should now be 12.375 each. sorry if the numbers arent the same on the design, It's just what i can see
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
86 Caprice Build
basically chop the box down the middle width wise and take a half inch on both sides out and then use that :good:
edit: keeping the center divider on the bottom 2 chambers
Edited by Jd1102
Ok, so I just cut my center divider .5 " on each side....cool
2006 Dodge Charger
(2) Kinetic 3800
(1) DC Power 270XP
(4) T1-12D4
(1) T2500BDCP
(2) T400.4
7.5 cubic ft.
(2) T165.2
(2) T169.3
I thought u only needed to regain half an inch?
yea sub track an inch from bigger chamber and .5inch form both smaller chambers width wise. And just out of curiosity, where does woofer get mounted? I have no experience with anything besides a basic slot box and would be interested in how these boxes work.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
