What Kind Of Amp Should I Use?
i think im going to w/ a pre-loaded Orion sub-package... ------>http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17777
what kind of amp should i run to it? i was thinking something like this ...
------>http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16368
can you more knowledgeable members help me out? if that amp doesn't match, can you guys post links of an amp that will match, and what kind of ohms should the 1000watts(about) should be running at?
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
look like a decent match but just a little over powered i think. give it proper electrical support though and youll, be fine IMO.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
i think you'll be happier buying the 2 subs and building a box... but the specs say that the box is wired down to one ohm. And i saw peak 2000W but no rms? So im assuming 1000. That amp is rated 1600 @ 1 but hifonics have never been my fav amps so i'd say its probably overrated a little. Maybe 1300 or so RMS so assuming the subs can handle a little over RMS you should be ok
play Moola.com its actually fun and free...
click here to join Money games!
its just games with free money!
maybe 1300rms haha its about 1000-1200 from what most people say and personally from owning this amp id say get a better amp, I learned my lesson dont buy cheap amps that say the put out good power, jus save up for the more quailty amp that puts out the good power....
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
IMO you can find something better for 550 you could put like 500 of that towards two subs and build a box with the rest. idk wher your from so prices prolly differ. but around here you can buy a 4 x 8 sheet of 3/4 mdf from home depot for 24 bucks. that would be more then enough to build a decent box that would better accomidate whatever subs you wanna buy.
your money would be better spent.
610EUROs
x2... by the subs seperate and build a box! and if you stick with those subs... look into how well they handle over-RMS power and get a RF t1000 but set the gaines a little low
  • 2 months later...
im tryin to figure out what kind of amp i should use for my subwoofers. i have 2 hifonics olympus 2412s. they are 2400 rms each and dvc 2ohm. i was considerin the hifonics collosuss i think it is, its a 5000 watt amp, but im not sure if it runs what it says
Fusion With A Stetsom 4k2d on 2 DC XL 15s tuned to 31hz and Subs and ports forward
The Revolution Was Not Televised
But There Is This Thread(clicky)
Dr Merkenstein is my 360 gamertag and my profession. When shit gets real, call in the Doc
