SnowDrifter Posted January 8, 2012 Report Posted January 8, 2012 How do you guys get the remnants of the spiders out? Mine have been soaking in acetone for a half hour to dissolve the CA glue, but I can still pick up the sub by the spiders. The sub is in my sig The only power tools I have access to are a drill w/ wire brush Pic of said sub: ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
mattp Posted January 8, 2012 Report Posted January 8, 2012 go buy a grinder! and get a blade to cut the spider down TEAM DC AUDIO 1999 Tahoe HU-Clarion flip out & Clarion EQS746 Mids/Highs Amp-MB QUART ONX4.125 Mids/Highs- Undecided Sub Amp-DC Audio 7.5 Subs-4x DC Audio xl 18s Alt- 270sp & 250sp Dc Power Big 3 1/0 http://dcaudio.us/ SPL-LAB sells rep. for IOWA http://spllabusa.proboards.com/
fmedina Posted January 8, 2012 Report Posted January 8, 2012 Cut as much as you can off or use a heat gun and grind off the rest with angle grinder. Maybe a dremel will work too with the right bit.
tlee2 Posted January 8, 2012 Report Posted January 8, 2012 cut the spider out as much as you can then get a flat head scewdriver or chisel and hammer the ca glue off it will come off easy like that. Then sand the rest off with a grinder or dremel 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333
SnowDrifter Posted January 9, 2012 Author Report Posted January 9, 2012 cut the spider out as much as you can then get a flat head scewdriver or chisel and hammer the ca glue off it will come off easy like that. Worked perfect, thanks! ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
FroznBeavrBALLs Posted January 9, 2012 Report Posted January 9, 2012 i used a box cutter and once you get underneath the spider it comes right up. Its gonna hurt your hands, probably, but it pretty much gets the whole thing off. Worked like a charm for me. lol 2 DC 12" lvl 4s 1 DC 1.2k XS Power S3400 big 3 Alll KNU wire Pioneer HU cheapo Legacy coaxes (just for now) http://www.stevemead...n-sentra-build/
D-train-13k Posted January 9, 2012 Report Posted January 9, 2012 Too bad I did all the work. Ass The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
tlee2 Posted January 10, 2012 Report Posted January 10, 2012 cut the spider out as much as you can then get a flat head scewdriver or chisel and hammer the ca glue off it will come off easy like that. Worked perfect, thanks! No problem 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333
SnowDrifter Posted January 10, 2012 Author Report Posted January 10, 2012 Too bad I did all the work. Ass What are you getting upset about? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
