I have a 1500 rf amp that is stable at two ohms I just want to know if it is ok to wire it down cuz I jave a d3100 and a 220 alt and 1/0 gage wire I think think after box rise and everything it wont see half ohm
I'm all for wiring amplifiers to 0.5 ohm but I would not recommend wiring that RF amp to 0.5 :No:
2011 Ford Ranger Sport 4.0 v6
2 sundown audio prototype nsv4 15s
crossfire 4k wired to 0.4 ohm
15 banks of maxwell 3.0 caps @ 18v
triple alts (x2 us alt 250's, x1 singer 320)
153 at 23hz
Ok thanks for the fast replys im just use to the way it sounds and I thought that I could make it louder with the lower ohm load I guess I have to upgrade to a bigger amp
If that amp is stable at two and above, why attempt to run at .5? I could understand if it was 1 ohm, then doing .5. You can't always also just say box rise. There's more too it.
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
if its 2 ohm stable that means you cant go below 2 ohm
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
I just figured that with the electrical upgrads I did it could have been done but screw it ill just have to make my woman mad and get a bigger amp lol
Lol. I wouldn't risk it on a 2 ohm even with proper electrical. But yeah. Bigger the better. ( most of the time anyway. )
Yea my subs are 1250rms I could go for a 2500rms amp and it would be perfect but if I could get away with it I really want a crescendo 3500bc amp and it would only be 250watts over rms for the subs wich I think they can take it and I would think I wouldnt even see 3500 out of it
Edited by dyablo409
Like everybody else said. I definitely wouldnt push that amp on .5 ohms. Now maybe if it was a 1 ohm stable amp then yeah id do it.
2002 Dodge durango 4.7L
Autopage 2 way remote start alarm system
2 AQ 15 Aluminum coils.
1 AQ2200D (soon to be 2).
8.5 cubes tuned to 38hz.
Yellow top under hood.
Kinetik 1800 in rear.
Big 3.
(H/O Alt Soon to come)
Kicker ZX200.4
Kicker 6.5 doors (blown)
RF 6.5 comp set (soon to come)
1 run of Stinger 1/0 guage (soon to be 3)
All of the above is all gone
Currently own a 2000 Pontiac Trans Am WS6
No audio components.
