My pvc diameter is 4in and 10in long there are 2 ports the box is fairly big im not sure of the spec because i didnt build it.
There is a divider in the sub box so each 15 has its own chamber. I didnt know that 2 mix matched amps would matter but all i had was the 1000watt soundstorm i had pushing my 10in type r and when i bought the 15's the guy gave me this 1100 walmart amp so i figured why not run both.
I have 4ga wires.
What amp would you guys recommend?
I would like to build a ported box. size is no issue I have a huge trunk to play with.
I had my 10in type r in a 6th order and it banged just as hard as one of the 15's so im sure i could get louder with a good box.
Should i buy 2 more audiobahn 15's ?
I know they arnt the best subs but they are 100 bux a pair.
your port seems small i got 1 sundown zv.2 10 in 1.25 cubes tuned to 31ish and my four inch id port is 22 or 23 inchs long
I have 17in tall 37in width to be safe and 35in depth
The box could go deeper into the trunk if it were shorter.
But id rather have it be just a bit smaller that the whole trunk so i wouldnt have to worry about fitment.
Walled 2002 buick century A.K.A "Betty sue"
polk 5 1/2 front doors
4 3in pillar speakers
DD 3518's
AQ 3500 v2
90ft of 0/1 ga
tuned to 40hz
:build: http://www.stevemeadedesigns.com/board/topic/162721-buick-built-in-trunk-fi-sp4-hifonics-2400/
im sure the port is small i just use spare pvc in the garage. lets just say i got inspired lol...
my current box is 15.5in tall 36in width and 16in depth. so it could be alot deeper.
DD 3518's
AQ 3500 v2
90ft of 0/1 ga
tuned to 40hz
The problem with my trunk is that it starts out wide then goes narrow after the first foot. so its like an upside down T shape if that makes cents.
DD 3518's
AQ 3500 v2
90ft of 0/1 ga
tuned to 40hz
like everyone else said you need a single amp to run both subs somehting that does 1000-1200x 1 @1ohm or the same power at 2ohm. upgraded power and ground wires to 1/0 gauge would help. better ported box and an additional battery or 2 depending on the amp you get. if you can afford it an ho alt. gotta pay to play.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
you have a good attitude so far nivram. so welcome to the forum.
keep the subs you have, dont buy more. sell the amps like the others said. build a good ported box and you will be happy. there are several guys on here that will design you a box for a small fee but it'll be worth it if you get a good designer. "ray" on here has a thread for people to request designs from him. he would be a good guy to go to.
Welcome to the forums but you have a lot to learn.
I suggest reading threads and learning as much as you can before trying to re do your system.
A properly build ported box will be much louder than a sealed box, but there is a lot more to it than just cutting hole and throwing in some PVC pipe. My 2 12s right now flex my winshield a little, so you just need to learn how to get everything working better together and you can do that.
^^ this!!
LOOK. LISTEN. LEARN.
almost everyone here is willing to help you and give you constructive criticism, but only if you're willing to accept it :drinks:
Man I'm glad I didn't lock this I get to witness two retards holding hands telling each other that it'll be ok because they are awesome.
the subs are 4ohm single coils, so i think I can only wire down to 2ohm And yea i know Everythings money!!
The buick is my winter car , Here in Michigan its no fun to drive the 97 trans am so i figure id at least be pounding if im driving a grandma whip =)
^ Thanks skittles Are good!!
Do you know around how much "ray" charges for a basic box?
DD 3518's
AQ 3500 v2
90ft of 0/1 ga
tuned to 40hz
  • Who's Online   0 Members, 0 Anonymous, 1501 Guests (See full list)
