your getting whine and noise out of nowhere too?!
im on the same boat as well.
but try what skyhigh mentioned.
im going to try this tomoro when im free.
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
Ok well, the problem persists.....
It is fine when I hop in the car but after i ride for a few and turn it up the whine just comes in, it starts remotely low then gets quite louder after a min or so..... Soo i will try and ground the deck with the amp and ground the rcas...
Any more input fellas?
Edited by bassrace
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
Tell me how it goes, bassrace.
I'm gonna ground my hu to a bar in the dash first to see if tht fixes the feedback.
Then if its a no go, ill go straight to a batt.
Lmk wats up
HMU!!!
95 Bonneville SSE
Lmk wats up
Is yours doing the same exact thing mine is? I've never heard of alternator whine just comming out of no where, it's someweird stuff.lol
I was thinking the same I will just run a ground to the batt and see if that's a fix. If not I will ground the rca's. It's raining here soo no glassing today, I guess I'll just do the fun stuff, troubleshooting.lol
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
It just started out of nowhere. Ever since I stupidly plugged the rcas when car was running/amp.
Pioneer hu will blow an internally fuse unlike other brands who use slow- blow ones
Today after work. I grounded my RCAs at the hu, grounded hu to inside dash bar, AMD also grounded it to one of the dual inputs for my amp.
But I still get alternator whine, white noise when nothing is playing, and pops and clicks when I brake or Rom my volume knob on hu up.
I don't understand what could be the problem...
I checked the grounds in my car and all but one to the chassis in the trunk was loose.( cheap wire broke terminal ring.)
I fixed that and still yet feedback.
I unplugged the rcas from my sub amp and still white noise coming from the subs when gain knob is maxed when no music is playing.
And even when the rcas or unhooked from the sub amp, I get clicking noise when rolling the hu volume anywhere from 5-20 when gain is maxed....
I've done everything I could think of besides checking the RCA jumper to the Pac-lc 1.
What could he causing all this feedback...
You cannot hear any of this noise when music is playing but once its quiet, you hear it.
Using my turn signal, flipping the headlight switch, and the press of the brake all cause pops and clicks through the highs and mids...
anyone has any idea what's going on.....
HMU!!!
95 Bonneville SSE
Poltergeist?
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
Has ANYONE had an alternater whine come in after they turn the volume up and play it at a decent volume?
Soo i get in the car start it, no whine.... Get going, no whine.... Turn the volume up to my normal listen level then let the song play turn it back down and suddenly a whine. I noticed it starts out kind of low, then gradually gets louder... I can turn the hu off, then back on and still get the whine(while driving)...
This is comming only from my mids....
Any input is greatly appreciated.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
i tried both of those and didnt work. my grounds are good. hope you find out buddy. wrst case scenario. whether anyone believes it or not, try replacing your condenser in your distributor
You lost me with the condenser in the distributor... Please explain..?
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
WheN I got my DD, I noticed alt whine as well. It turned out that a wire BEHIND my HU was touching metal which cause alt whine. Moved it and it's golden now. Only way to pin point is, as youalready did, recheck wires and grounds. If you for some reason had your HU playing and plugged/unplugged your RCA/s, it may them.
loose rca. ive had mine pop out on a bump in the road once. did the exact same thing.
  • Who's Online   0 Members, 0 Anonymous, 596 Guests (See full list)
