maybe the photon particle accelerator needs recalibrating?
Nah, im Just playing, maybe one of your rcas came unhooked? do you have a line driver that you adjusted, and forgot to re-adjust
If you are getting noises through mids and highs.
Check grounds.
But pioneers blowimg pico? fuses are common. Google the fix
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
did you turn the sublevel output down on the head unit if you have that feature.
no, i don't have that option on the headunit.
And to everyone.. i had a batt in the front and one in the rear, the one in the rear fried. I only have a single 9515 DD.
and i never messed with the gains at all after the battery fried so it can't be that.
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
Audison Bit One processor
Jl-cl-rlc line driver
iPad in dash
Dual Irragi 320a alts
8 batcaps 4000's
Second Skin sound deadened
could have blown 1 side of the coil. how do you have it wired ?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   0 Members, 1 Anonymous (See full list)
