running a saz 3000d @ .5OHM NOM TO 4 SA8 D4'S, HAVE A DC POWER XP270 ALT WITH 2 AGM G31 BATTERYS, JSUT GOT SYSTEM HOOKE UP AND 2 TIMES NOW AMP HAS GON INTO PROTECTION.. MY VOLTS HAVE NEVER DROPPED BELOW 13.8 TYPICAL STAYS IN LOW 14.XX SITS @ 15.0 AT IDLE. FIRST I THOUGHT VOLTS WER DROPPING TO LOW BUT THATS WASNT IT. SO NOW I HAVE NO IDEA WHERE TO LOOK TO RECTIFIY THIS PROB?
You said .5 ohm nominal. What's the ohm load sit at right now? Could have a blown coil causing the amp to protect.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
^^^ what he said, i would go over with a meter and check all of your voice coils to make sure everythings okay
I didn't even bother to read your post because YOU TYPED IT IN ALL CAPS!
Big 3 with Yellow Top
RECHECK ALL OF YOUR WIRING! DID YOU MAKE SURE YOU AREN'T CLIPPING THE HELL OUT OF THE AMP!?
2004 Volkswagen GLI
1 10" Skar VVX
^^^ Looking for an amp to run it, Pm me if you have one ^^^
It is very annoying when you break the caps lock key. Please don't do that.... I've heard many say that amp will run at .5 ohm all day, so one of your subs might have a hot spot on the coil heating up. It could also just be one of "those amps" that can't handle the .5. See if sundown will let you trade it.
Just an FYI, you void the warranty when you run sundown amps below 1 ohm
2000 Subaru outback 2.5l
Head Unit: Pioneer deh 4300ub
front stage: tbd
subwoofer: Stock Fi Q 18"
amp: Audio que 1200d
  • Who's Online   1 Member, 0 Anonymous, 1717 Guests (See full list)
