stevog Posted January 13, 2012 Report Posted January 13, 2012 this would be a decent system for about 585 but you would still need wood http://www.sonicelectronix.com/item_29711_Hifonics-HFi1000.1D-Amplifier-Kit.html http://www.woofersetc.com/p-9576-sa-15-d4-sundown-audio-15-600w-dual-4-ohm-sa-series-subwoofer.aspx http://www.sonicelectronix.com/item_31077_Pioneer-DEH-P8300UB.html
kraz1021 Posted January 13, 2012 Report Posted January 13, 2012 a good 15 subwoofer is going to be atleast 200 and the amp maybe 150 plus the wiring and stuff 50 wood and screw 45 headunit 120 thats already 565 so budget has to go up unless you already have some of the stuff. ^^^^^^This.theres more to a system then just subs and a amp.new amp=you might need bigger/more wire,new sub(s)=materials for a new enclosure.small things like that can add up fast.if your budget is only around 300 id look for some quality used equipment
TheNewbie Posted January 13, 2012 Report Posted January 13, 2012 But a $300 budget ain't gonna get you nothin worth having That is the dumbest logic ever. I know tons of people, including myself, that have spent less than $200 on systems and they are definitely "worth having". Maybe not to someone that has high standards, but not everyone does. I just want something that hits harder than what I have which is 2 low rms 10's on a low rms amp with no port on the box. Simple. I'd like help, not insults. I agree with you, most on the forums do have high standards for car audio, being that it is a car audio site. None the less I as well didn't have as high of standards when i first started. (Not saying your just starting) but i think what everyone is trying to say indirectly is to save your money for something you'll be alot happier with rather than buying something within your budget and it going out, or wanting more. You can for sure get a setup with 300 dollars, but it might consist of cheap wires, cheap amp, and a good sub. You don't wanna cheap out on anything because you'll end up spending more money in the long run. I don't think it's to much as everyone else says "Never to much" but I also think even if you don't have high standards you should save and buy items of quality that will last you longer. Just my 2cents. EDIT: Ever think about 2 12s? Less cone, but could run you a bit cheaper and would most likely be louder than your 10's depending on what the 10's are and what 12's you'd get. Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
stevog Posted January 13, 2012 Report Posted January 13, 2012 dont worry about shaking the car to much its just a prelude its not like its a ferrari or something. like others have said you can just tighten the things back up. also like thenewbie said 12s also sound good but do it right do it once get the good stuff now and you dont have to replace it later.
LoudBimmer Posted January 13, 2012 Report Posted January 13, 2012 For $300 you can find "5000 watt" system at your local flea market
bassrace Posted January 13, 2012 Report Posted January 13, 2012 I'd say shop craigslist for something cheap if 300$ is for everything. Or you could buy one item at a time till you have what you want/need and possibly be way happier. I'd start with wires, hu, then sub/subs, then amp. I would just buy as you can so you end up having decent equipment instead of spending all your money at once and be dissapointed. Just imo though. 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry
tlee2 Posted January 13, 2012 Report Posted January 13, 2012 But a $300 budget ain't gonna get you nothin worth having That is the dumbest logic ever. I know tons of people, including myself, that have spent less than $200 on systems and they are definitely "worth having". Maybe not to someone that has high standards, but not everyone does. I just want something that hits harder than what I have which is 2 low rms 10's on a low rms amp with no port on the box. Simple. I'd like help, not insults. That wasn't a insult but i just dont see how its possible to put together a decent setup for 2 15s for $300. Am i the only one? 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333
stevog Posted January 13, 2012 Report Posted January 13, 2012 i agree theres no way a decent system can be built with 300 dollars we should make a challenge for whoever can find a decent system with 2 15s for 300 or under but only using new stuff.
pimpnFosgates Posted January 13, 2012 Report Posted January 13, 2012 you can get the new skar audio ivx 15 and a aq 750 for 330 to 370 i believe. 1 15 and 750 watts. good equipment.just saying Lucky Durango Sony hu 4 croosfire 6.5mids crossfire 600.1 mono amp American bass 1280.4 mids and highs amp aq hdc3 12 2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
pimpnFosgates Posted January 13, 2012 Report Posted January 13, 2012 4x8 sheat of .75 mdf 30 bucks.hard as nails 6 bucks. pvc for ports 12 bucks for 10 feet. 50 ft of 4 gauge(beginner style) 34 on ebay. Lucky Durango Sony hu 4 croosfire 6.5mids crossfire 600.1 mono amp American bass 1280.4 mids and highs amp aq hdc3 12 2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
