Hi, i have 2 12" JL w6v2's just bought from a JL authorized dealer, and a custom box they built with the subs facing down and port out the front.
When the subs play anything below 30hz they make a very werid rattling noise, it is bearable but noticeable enough to have me worried(Almost sounds like a knocking). I can not tell if its the structure of the box or the actual subs making this noise, Any and all opinions are welcome !!
http://www.youtube.com/watch?v=Y1q4efcqezU&feature=youtu.be
---Happens at ---
3-5 seconds
13-15 seconds
22-24 seconds closest to side of sub woofer
JL Audio actually faxed the dealer the box design claiming it would work best in a softtop vehicle
HD 1200.1 amp
Head Unit Settings From Dealer
Bass = -6
Sub = +10
Treb = 0
Fade = +R2
Edited by BillKessel
---Happens at ---
3-5 seconds
13-15 seconds
HD 1200.1 amp
Bass = -6
Sub = +10
Treb = 0
Fade = +R2
sounds like your box is coming apart a friend of mine had the same issue pulled the carpet back off the box and you could see it coming apart just a thought
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
Could be the wood cracked or maybe the wires from the subs slapping the box on the inside.
Vehicle
2007 Chevrolet Avalanche(Co-Co)
DNX9980HD
6 Team Fi 15's(King Edition)
3 DC 9k's
8 Nendo PWX 8's
4 Custom Steg 4" Super Tweeters
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
3 DC Power 370xp Alts(Externally regulated)
21 D1600's
2 D4800's
All SMD RCA's
AudioTechnix Deadner
Viper Alarm
My YouTube- http://www.youtube.c...NG?feature=mhee
Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/
Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
---Happens at ---
3-5 seconds
13-15 seconds
HD 1200.1 amp
Bass = -6
Sub = +10
Treb = 0
Fade = +R2
Thats what i am thinking, Ive spent 1700 dollars on this system and he refuses to take a glance at it. He claims its my truck rattling and i can bring it in next week again for another check. Ive spent over 4,000 dollars at this store, ranging from car alarams , remote start + Smart Phone start , 2 amps, and many subwoofers. this is the last time i let someone else install my stuff! :)
Sounds like you are simply bottoming the sub out. Basically over excursion, causing the coil to hit the bottom of the motor. Usually a result of playing below tuning with no subsonic filter set.
What is the box tuned to?
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Yikes, i will have to call the guy and ask what the box is tuned to. Didnt know you could bottem out at 30 HZ but play 40hz and 20hz just fine? the subs do make a clapping noise almost when bass plays if you lay your head near the box, ( no matter what song )
Maybe its just my computer speakers but that didn't sound throaty at all it sounded like craacking would or something slapping the inside of the box.With the bass playing it's possible for the wires to slap the box hard enough and fast enough to sound like that. Worth checking out.I would pull the subs out and check the inside of the box for cracks and see if the wires are slapping the box.
Vehicle
DNX9980HD
3 DC 9k's
8 Nendo PWX 8's
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
21 D1600's
2 D4800's
All SMD RCA's
Viper Alarm
It could possibly be a loose dustcap too. I believe those JL subs use a full cone dustcap on them, so it should be easy to tell if that's loose. Sounded just like that when my friend's dustcap came unglued. If so, take care of it right away. We didn't get it taken care of immediately with his sub and the dust cap flew right off taking a good chunk of the cone with it.
Pull the sub out and free air it, but be careful with the volume. See if it still makes that noise. Should rule out whether it's the box or not then.
My Saab 9000 build
I agree, sounds like something on the speaker itself is coming loose. Reminds me a lot of tinsel slap that you used to hear a lot in the days before they tinsels were sown into the spider.
Taking it out and play some tones to help isolate it rather then music, but like Autruche said, be careful as it is fairly easy to over drive a speaker like that.
