fecupe2001 Posted January 14, 2012 Report Posted January 14, 2012 Ok guys, after the "1500 watts amplifiers challenge" i took out everything from the sexplorer, is time to move on and try a bandpass for hairtricks using small cone area, but anyways, i was kind of boring and i wanted to try something fun, hitting over 140 dbs with a DAILY box , cheap equipment on small power and very small cone area, all of this things on a big ass cabin 1) Step one: Getting a cheap sub, i found a Pioneer Champion TS-W258D4 350 watts DVC 4 ohms for 15$ , it didn´t look that bad actually, price it´s something like 45$ if you get it brand new if i´m not mistaken Specs: Features Maximum input power 1.200 W Nominal input power 350 W Impedance 4Ω Frequency response 20 - 450 Hz Lowest resonance frequency 37,4 Hz Sensitivity (1W/1m) 90 dB Woofer size 25 cm Woofer material Interlaced Basalt / Aaramid Fibre Reinforced IMPP Composite Cone Dual 4Ω voice coils: 2 or 8Ω Yes Voice Coil bobbin type Phenol resin coated glass cloth bobbin Pole Yoke Type Extended and Vented pole yoke Magnets Double-stacked, high power Terminals Push-type Recommended sealed enclosure 18,4 - 35,9 litres Surround 3-Layer Fiber Woven Radial Surround Technical Specs Nom. Dia.(In) 10 Qts 0,48 Qms 11,52 Qes 0,50 Fs [Hz] 37,4 Vas [l] 17,63 Vas [ft3] 0,620 Vd [l] 0,326 Vd [ft3] 0,01151 Sd [m2] 0,03134 Sd [ft2] 0,337 Revc [Ω] DUAL1.5 Levc [mH] (2000Hz) 2.2 (4Ω) 0.63 (1Ω) Xmax [mm] 10,4 Xmax [in] 0,41 Zmax [Ω] 96.01 (4Ω) 19.95 (1Ω) BI [Tm] 14.68( 4Ω) Rms[Ns/m] 2,920 Mms [g] 143,28 Cms [m/N] 0,00013 Mg.Wt.[g] 2100 VC.Diameter [mm] 48 Eff [%] 0,18 S.P.L. [dB] 90,0 R.M.S.Power [W] 350 Sp. Displacement [l] 1,64 Sp. Displacement [ft3] 0,058 Recom. Enclosure [l] 22,6 Recom. Enclosure [ft3] 0,80 2) Step two: Get yourself a cheap ass amplifier, i used my old trusty Almani PA1100.2 amplifier, it cost about 100$ brand new, no complains about this little baby, i´ve abused it with 4 mids for about 2 years now without a single problem, of course, since the sub it´s DVC 4 ohms i wired it at 2 ohms P.S: I forgot to take pictures of the amplifier, don´t think you need them tho, if you don´t trust me then i guess i could take some pics tomorrow if you need me to Specs: Almani PA-1100.2 Description * Soft turn ON/OFF * Nickel Plated RCA Jacks * 2 OHM stable operation * Power and Protection LED indicators * High efficiency, heavy aluminum heat sink * Nickel plated power and speaker terminals * All models are bridgeable and stable at 4 OHM * Class "AB" Technology MOSFET PWM Power Supply * Protection circuites against: Overload, Thermal, Reverse Polarity * RMS Power @ 4ohm: 275W x 2 * RMS Power @ 2ohm: 550W x 2 3) Step three: Get yourself some cheap ass plywood (had some scrap wood on my storage so i didn´t spent anything on this) , screws, glue and wires, total cost: around 32$ 4) Step four: Build your ugly ass box with your cheap materials, box specs: 1.2 cubic feet and 17.5 SQ of port with a 40 hz tuning 5) Step five: Get your ass to my "SPL Gains topic" and use some of the tips i tested over there, if you haven´t visited yet, check it out, use as many things as you can. SPL gains topic Printing vinyl 45´s on the pressure corner: DONE!! (no pics) Roundover on the sub hole : DONE!! (no pics) Sexy ass flare using 3/4" pvc strips outside and insinde of the port: Tape around the sub: And finally, metering your ugly ass box on your SUV: Score is sealed on the dash @ 47 hz, plays very nice from 40 to 50 hz, below or above those points it sounds like shit, lots of clipping on that score since i was too lazy to set the gains properly because i don´t give a fuck about that sub lol, so i just burped rolling up the volume knob of the HU and that was it, also, i bass raced a 139.4 using a song from my boy Decaf wich is constant @ 47 hz, with a couple of tweaks i´m sure i could bass race a 139.9 but i´m just lazy as hell since it was just for fun, hope you guys like it Money spent (without including battery, wires and HU): Around 160$ I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
alaskanzx5 Posted January 14, 2012 Report Posted January 14, 2012 for the price, that is a great score. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
fecupe2001 Posted January 14, 2012 Author Report Posted January 14, 2012 for the price, that is a great score. Thanks man, it was a fun 2 hours project, and that´s because i wored very slowly since i was drinking a lot haha, once again, i only spent like 20$ since i had some scrap wood, screws, glue, printing vinyl,the amplifier and some cheap wires, but if someone would want to build this same exact system, i guess it would cost less than 200$ without including the HU and the electrical I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
fecupe2001 Posted January 14, 2012 Author Report Posted January 14, 2012 Lol nice.. I thank you I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
Mad_Mike Posted January 14, 2012 Report Posted January 14, 2012 You should grab another sub and make a box run on the same amp, see what cha get.
Quiet Posted January 14, 2012 Report Posted January 14, 2012 Goddamn I thought I was cheap HAHA! that's awesome, bro But can you do a fiddy with $400? 2007 Pacifica Rebuild. Less quiet. Still not loud.
fecupe2001 Posted January 14, 2012 Author Report Posted January 14, 2012 You should grab another sub and make a box run on the same amp, see what cha get. Should be fun, don´t think i´m getting another sub tho since i want to build a BP now, BUT, a very good friend of mine has 2 pioneer champion 12´s 400 watts a piece, he wants to build a new box, so i´m gonna build it next week before the bandpass and try it out in the explorer, should be fun, a pair of 60$ dollar subs and around 1000 watts, we´ll see Goddamn I thought I was cheap HAHA! that's awesome, bro But can you do a fiddy with $400? hahaha well just have to remember something, it plays very nice but on a small bandwith, below 40 hz it sucks, above 50 hz starts playing like shit also lol, you can´t say it´s a very flat respond box but who cares??? it was fun anyway : What´s fiddy?? I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
Quiet Posted January 14, 2012 Report Posted January 14, 2012 You should grab another sub and make a box run on the same amp, see what cha get. Should be fun, don´t think i´m getting another sub tho since i want to build a BP now, BUT, a very good friend of mine has 2 pioneer champion 12´s 400 watts a piece, he wants to build a new box, so i´m gonna build it next week before the bandpass and try it out in the explorer, should be fun, a pair of 60$ dollar subs and around 1000 watts, we´ll see Goddamn I thought I was cheap HAHA! that's awesome, bro But can you do a fiddy with $400? hahaha well just have to remember something, it plays very nice but on a small bandwith, below 40 hz it sucks, above 50 hz starts playing like shit also lol, you can´t say it´s a very flat respond box but who cares??? it was fun anyway : What´s fiddy?? My bad, let me translate: Good sir, would you propose a sound pressure level of one hundred and fifty decibels would be possible, pray tell, from a combination of equipment acquired for the fair sum of four hundred dollars? 2007 Pacifica Rebuild. Less quiet. Still not loud.
Mad_Mike Posted January 14, 2012 Report Posted January 14, 2012 That actually sounded rather educational
