Re test the 4 channel and see if it starts to do the same thing. If it doesnt, then there could be something wrong with your bass amp? Any friends with equipment to test the dd1 with?
I will try that out tomorrow.
What could be wrong with the amp?
What type of equipment?
Equipment as in do you know anyone that has amps and such in the car that you can test the dd1 with to make sure that something isnt wrong with your amp. Im not saying that there cant be something wrong with the DD1. I think that that t his would be easiest thing to do. Im not sure what could be wrong with the amp, just throwing out some suggestions.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
Posted (edited)
Oh I got you. Yea Im going to test it out on my highs amps today to see if the readings come out the same.
Edited by Trill985
I tested out my DD-1 on my high amps. It worked just as good as the first day I set them. Im not sure what is going on with the sub amp. Maybe it is setting correctly but when I did the old sub amp that I had the gain was set alot higher than what it is with this one. Not sure what could be going on.
When I tuned mine, I checked both running and off and Diddnt make a differance. To be safe, tune car not running. So it looks like something is going in with your sub amp then.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
You're not comparing two seperate sub amps are you? Even if they are the same model the gain won't be in the exact spot on both
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
x2
and the h/u has to do at what level the amps will start to clip, different h/u send different amount on voltage to the amps so if you have an amp that does not clip with one h/u it dont meant it wont clip when you install it to a different h/u
x2
He changed out the sub amps, not the head units
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
x2
just letting him know that an amp can clip even if it wasnt clipping on an earlier install, if i remember correctly he said he bought the amp from someone else used plus he is testing 2 amps and trying set them the same, even if they are same brand same model it will clip and different gain settings
  • Who's Online   0 Members, 0 Anonymous, 326 Guests (See full list)
