You might want to consider a DC 5k or similar. From what I've heard, having multiple amps is less efficient and plus you would have to worry about the stability of multiple amps at an unusual resistance. So if you put a 1.34ohm load on a DC 5k, I would think you get around 600-650 watts RMS per sub. If you got the 7.5k, you should get around 900-950 watts RMS per sub. That doesn't take into account impedance rise, stable voltage, etc. although you did mention your electrical can hold 6k easily.
Please correct me if i'm wrong on any of this. Thanks!
Wrong but the user learning curve goes way up using multiple amps! The benefits are the box rise is split between the amps there for each amp is more efficient.
TEAM FLEX ISSUES, TEAM DC AUDIO
2010 California State Finals Champion MECA AS2
2011 California State Champion Meca S2
2011 California State Record holder Meca S2
2012 Meca Mod 4 class 152.5 and rising
