One is wired wrong canceling each other out
their both wired the same i didnt hook anything up differnt then the way i did the first time.
I understand this may be true, but the fact of the matter here is that you DID do something different than when they were first hooked up. You need to be willing to understand that user error is a possibility and you need to verify everything.
id pull them out of the box to look at the wiring.
Yeah thats the next thing i did too see if they came unhooked pulled the box out. pulled both subs and they where fine and hooked up right. their wired down to 2ohm to the box then their bridged at the amp if that helps any.
Yeah i understand i did but i cant figure it out, it all looks the same it has to be one of those mistakes u dont think is wrong type of things cus ive gone over it three times.
If there are 4 wires coming out of the sub box then make sure positive goes to positive and negative goes to negative. This will make sure they are not wired out of phase.
Edit: Nevermind I see you did it.
Edited by joshywb121
Basshead-in-Training
what it sound like is a cross sub wire what i do is turn the head unit up jest a little and unhook one sub and of it gets loud i no that is the sub wire crossed good lucky
ok ill try that and if that is whats wrong what causes it and how do i fix it.
  • Who's Online   0 Members, 0 Anonymous, 2993 Guests (See full list)
