I just built a 8 cube box for my 2 15's however im not sure how to slot port tune so im not sure how long to make my port. the box is 17height 24 lenght 36 width i cant only make my port 4in wide and 16in tall due to the short width for the 15's but im not sure how long to make it. please help!!
Im in search of 30hz ;)
Walled 2002 buick century A.K.A "Betty sue"
polk 5 1/2 front doors
4 3in pillar speakers
DD 3518's
AQ 3500 v2
90ft of 0/1 ga
tuned to 40hz
:build: http://www.stevemeadedesigns.com/board/topic/162721-buick-built-in-trunk-fi-sp4-hifonics-2400/
haha wow....with those dimension your box has an internal air space of only 6.96 cubes not 8 lol.
2000 Dodge Durango
Subs - (2) SKAR VVX 15 D2's
Box - 7.2 ft^3 @ 33hz, 120 in of port
Sub amp - Digital Designs M2 @ .5 ohm
Mids + Highs - PRV Audio
Mids + Highs amp - Hifonics 2000.4
Headunit - Alpine CDE-100
Equalizer - Clarion EQS746
Batteries - Mopar group 27 + (2) C&D 52ah
Wiring - 1/0 BIG 3, (2) runs 1/0
Alternator - Singer 250A
147.79 dB @ 35hz - burp - sealed on dash
147.47 dB @ 35hz - music - sealed on dash
YOUTUBE: http://www.youtube.com/user/321slapinBass/videos
its external measurements i used 3/4 wood. i built the box as big as i could and it hardley fits in my trunk will have to cut out some of my rear deck because of how big this box is.. there is no way i could go any bigger with a rectangle box.
Either way the subwoofer requires two 4in x 9.5in long round ports so with 2 subs i figured 16in x 38in long but im not sure how to determine the proper slot port calculations.
either way im just looking to make the most of these 2 15's
DD 3518's
AQ 3500 v2
90ft of 0/1 ga
tuned to 40hz
statingrobin^ a port that small will actually give me a low tune? ive always thought the longer the port the better. the t line ports are huge!!
DD 3518's
AQ 3500 v2
90ft of 0/1 ga
tuned to 40hz
Less port area= lower tuning More port area= higher tuning Longer port= lower tuning Shorter port = higher tuning
Btw a 4"x6" port wont cut it.
Fixed
Edited by joshywb121
Basshead-in-Training
^^^^this!!
By the time you get the correct size slot port in that box and account for driver displacement, I bet you are around 5 cuft.
Might want to look at aeros instead of a slot.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
If i could have built a bigger box i would have but i cant. it just wont fit!!
All i want to know is what size slot port to build and how long. i just want my 15's to sound good. my 10' type r in my 6th order box is louder than the 2 15's in my current ported box that i pvc ported. ive never had any luck with round ports. i would like to have my slot port be 16in x 4in but im not sure how long to make it.
the subwoofer requires two 4in x 9.5in long round ports so with 2 subs i figured 16in x 38in long for but im not sure how to determine the proper slot port calculations.
So the longer my port the deeper lower tune? t line boxes have a stupid long port
DD 3518's
AQ 3500 v2
90ft of 0/1 ga
tuned to 40hz
