It didn't do thus on my other sub.. :/
explain
I had this same channel running my mtx and it sounded just fine. But on these sa8s it sounds like they are bottoming out
how long have you been running the setup with the SA8's?
Since today
getting rid of that amp seems to be the ONLY thing to do right now. i know its all you have for now, but dont risk burning up decent equipment with a faulty amp.
1992 Camry "Stormtrooper"Quantum Audio DVD/USB/AUX 3.5" single din H/UXS D690Cadence 0g wiring and Kicker 4g wiring(2) Selenium 6w4p's(2) Selenium ST200'sKicker 200.4 (mids & highs)(1)Kicker and (2)Stinger RCA'sSecondSkin in trunk and doors12K HIDsMulitcolor Angel EyesSoon to be done:Big 3Mechman H/O Altsubs?amp?
That thing is going to eat people nearby cars, unsecured objects, and small children
Fixed!
wow nice. i wanted nos on my car but the gf said no. i was just gunna do a 50 shot tho haha
Get a new girlfriend.
i did not flame you but your car might useing that amp
im telling you that what you are doing is dangerous sorry if im blunt
I won't use that amp anymore. I was just worried and wondering why my subs are making that weird noise. Thanks
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
Posted (edited)
if the subsonic is tuned lower than what the box is tuned to it will make it bottom out
edit: if the box is at 32hz set the filter to 27hz or above like 30hz to be safe since you dont know where that is on the amp
Edited by Miguels
explain
Since today
I will get rid of that amp. Thanks! I will hook the subs to my mids and highs amp tomorrow
My Truck Build
Tuned to 33 hz. Thanks for the help everyone! You made me feel better knowing it's the Amps
My Truck Build
If your that determined to test/hear before you get the Fosgate. Test each sub one at a time on the good channel of the amp. Obviously the amp does not like load its seeing. I know the specs of your box. It doesn't sound like they are bottoming out.
Make sure its the amp thats broke and not the rca switch the working channels RCA over to the broken if that channel still doesnt work then ditch the whole amp. you got sundowns anyway so i wouldnt run a POS on them honestly
Just another lurker
watch out with cheap amps i remeber people buying jensen back in the days, they used to burn up your voice coil
K cool! As long as it's the amp and not the subs in good :)
My Truck Build
