Help cramming 18 into the trunk
8MileRoad
Max Depth 28
Max Width 32 (safely 30)
Max Height 14
Desired Tuning is 34 HZ
Only option is to upfire
Here Are Some Specs
Ported Minimum Box Volume 5.5 cu. ft. Maximum - 8.0 cu. ft.
Mounting Depth - 9.6"
Woofer Displacement - 0.22 cu. ft.
Can someone please pm me an ideal port design for this box (34hz 32 Would be great)
port has to be wood no aero :(
the brand and model of woofer would greatly help..
i put these dimensions in - 14x32x28 - that you gave, no other numbers input and your net space is only 5.85 cubes, gonna tell you right now, you will not get that 18 in your trunk in a proper box, no way in hell especially if your looking for any lows
cut it up and recone it as a 15 is my suggestion
4.38 after all displacments with a tuning of 33hz was the best i got, thats including stupid small port area, gonna be too small for any 18
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
I think you would be better off with 2 12's instead of 1 18'(in case you haven't bought it yet) in my opinion since your trunk is small.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
This is actually pretty easy. 1) put 18" woofer in trunk. 2) admire woofer in trunk. 3) tell buddies you has 18" woofer in trunk.
Or find a sub that will fit in those specs. 2 12s would be easy and comparable cone area iirc.
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
Max Depth 28
Max Height 14
Here Are Some Specs
If you really want to do this I would suggest building down into the spare tire well. I was able to get 1-18" front firing sub into my 94 honda accord trunk by using the spare tire well for air space and I used it to gain the height on the baffle wall to even fit the 18" in there. You will have to build a custom fiberglass tub and glass that to the box but it works, it hits the lows, and its loud. Plus it won't rattle like it will when you fire that thing up.
http://i484.photobucket.com/albums/rr201/kreepn/IMAG0834.jpg
http://i484.photobucket.com/albums/rr201/kreepn/IMAG0444.jpg
http://i484.photobucket.com/albums/rr201/kreepn/IMAG0456.jpg
http://i484.photobucket.com/albums/rr201/kreepn/IMAG0463.jpg
http://i484.photobucket.com/albums/rr201/kreepn/IMAG0475.jpg
http://i484.photobucket.com/albums/rr201/kreepn/IMAG0482.jpg
http://i484.photobucket.com/albums/rr201/kreepn/IMAG0497.jpg
http://i484.photobucket.com/albums/rr201/kreepn/IMAG0838.jpg
It would do a 149@35 hz on the dash windows open. I will warn you this is not for the 1st time installer though, it is a pain in the ass to build like this in the trunk. ;)
  • Who's Online   0 Members, 0 Anonymous, 1278 Guests (See full list)
