you have two much going on. hook up all your batts first. then hook up your amps. you've got fifteen things that can be factored in. start cutting things out and isolate the fault.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
if you hook up ground frist then go to add power and it sparkes you take the power off no more sparks.. if you have power on frist and something grounds out guess what its a lot harder to stop.. if hooking up power frist if something grounds out when you already have a few powers hooked up how do you disconect fast?
You connect the positive first because it changes nothing by hooking up the ground first you have now given the battery a circuit and is now considered "hot". The reason why any battery would spark while connecting the ground is because somewhere in the circuit something is drawing power, whether it be the dome light because the doors open or the simple constants to clocks and radios. All of those things would cause the battery to spark a little at connection.
I've always hooked my positive up before my ground.
i bet you 2 dont charge the caps in your amps before hooking them up ether guess im just use to 20,000 watt plus systems
So you have no ground connected right now to the chassis frame or engine block? I am on mobile so it's hard to tell
nothing grounded on the frame gets hooked up until that orange spot with all the grounds makes contact.
i have always gotten a little spark, but it was an amber colored spark, this was white/neon blue almost and melted a tiny piece of the bolt when it was connected.
edit: is the bass amp reading 2ish volts because of the caps in it?
edit #2:
can i just take the fuse out of the positive run? to take them out of the equation?
Edited by ChevyBoy95
I'm talking in general. Not system wise.
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
You don't have to run a 20kw system to know this it's common knowledge
you win some, you lose some
you could
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
You have a direct short on a power wire some where.. when you hook up grounds its completeing the circuit and blowing the fuse.. make sure power wire or lug isn't touching back of alternator case.....hook up all batterys 1st with frame grounds also... do big 3 up front... then wire up amps.. always ground the amp 1st,then the pos, then remote, then rcas... if you hook up pos wire 1st to amp it will search for ground and if you plug in rcas guess what blown rcas on deck and other equipment... meaning bad engine whine......and who kinows what else possible blown remote output from deck also.. find the short... if only the alternator fuse blew then its close by there imo..
Edited by dc98hoe
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
  • Who's Online   1 Member, 0 Anonymous, 1377 Guests (See full list)
