Basically what the title says, I was going to recone my 12"s to 15s but I can get around 7 ft net after all displacements without having to build in the trunk. Is 7 ft net too small? 3.5 net per just sounds small for these subs.
Please ppl with actual experience chime in.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
My 12"s seem to like around 2ft3-2.25ft3 with the rated 2500rms I'm running, and that's what I will be running on the 15's at first. They say around 5 net per 15 but I will have to build in the trunk for that space, if it wont be enough space I might try an hdc4 18.
I'm just looking to switch up the system a little bit.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
im putting my sa15s in 5.99@ 31hz you should be spot on for 7cu
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
what power are you guna put on these subs? that orion in sig?
Yeah, for now.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
I would look at 4.25 - 4.5 per. I wouldnt go 5. That seems to much.
Well my debate was I had 3.5 net per sub any more and I will have to build inside the trunk which I am not doing.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
you have 7 cubes of space in your trunk without having to build inside the trunk?? damn i wish i had that kind of space.
how do you plan on orienting the woofers and the port? from what i've heard and experinced subs up in a trunk is really inefficient. i usually stick with less is more in a trunk, but i'll let you be your own judge there.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
Aeros, to the side or forward, still decideing on that. And subs toward the cabin, not up.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
its on the fence. if you got power you can get away with it.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
My thoughts exactly... With the power I have, I know wont be enough, but double the power and then we're talking.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
  • Who's Online   0 Members, 0 Anonymous, 492 Guests (See full list)
