MD7786 Posted January 20, 2012 Author Report Posted January 20, 2012 What about do big 3 with another yellow top in trunk? Isn't it true i gotta keep batteries the same when adding? Quote
corey0928 Posted January 20, 2012 Report Posted January 20, 2012 Same type you can mix brands just Dont add a amg battery with a acid or wet cell Quote
new guy Posted January 20, 2012 Report Posted January 20, 2012 you can use different brands of batteries as long as they are both agm. id just do the big 3 first it should help alot. Quote *current* 1991 honda crx si 2 skar audio 12s pioneer 6.5s dual 400 watt amp audio technix db 1/0 wiring kit. dual head unit
MD7786 Posted January 20, 2012 Author Report Posted January 20, 2012 Well I can get ahold of a new yellow top for 50 so would that be a decent alternative to ho alt? And how wapuld i do it. Have my amp wire connect to it then run more to the amp from that one? Quote
new guy Posted January 20, 2012 Report Posted January 20, 2012 (edited) yeah that should be more then enough. just run 2 runs of 0 gauge from your front bat to your back one. hook up your amp to the back bat. also make sure you have a very good ground for your front bat Edited January 20, 2012 by new guy Quote *current* 1991 honda crx si 2 skar audio 12s pioneer 6.5s dual 400 watt amp audio technix db 1/0 wiring kit. dual head unit
MD7786 Posted January 20, 2012 Author Report Posted January 20, 2012 Where would the bbest ground be? Ots a 01 Camry. Quote
new guy Posted January 20, 2012 Report Posted January 20, 2012 anywhere on the frame or really any bolt that connects to the frame. Quote *current* 1991 honda crx si 2 skar audio 12s pioneer 6.5s dual 400 watt amp audio technix db 1/0 wiring kit. dual head unit
MD7786 Posted January 20, 2012 Author Report Posted January 20, 2012 Sounds good. Running 2 yellows seems cheaper than the 400 it cost for a ho alt I'm looking at. That ground will b part of big 3 correct/ Quote
new guy Posted January 20, 2012 Report Posted January 20, 2012 yes. upgrade alt power wire to bat. bat ground and engine block ground. Quote *current* 1991 honda crx si 2 skar audio 12s pioneer 6.5s dual 400 watt amp audio technix db 1/0 wiring kit. dual head unit
corey0928 Posted January 20, 2012 Report Posted January 20, 2012 You Dont need 2 runs of 0 gauge for 1000 watts. Just run one run from front battery to rear battery then run wire to the amp from the back battery Quote
