I'm working with 2kw @ 1ohm. And 1500ish @ 2ohms. I will get 1 18 for now and run it at 2 ohms. Then buy another when I build my wall and drop it to 1ohm. Anyways, I just wanted some people with first hand experience to let me know what they think. Price is a HUGE factor for me, being 16.
Here's my unfinished box if anyone cares to see. I also need some help calculating the slot port for 33hz. I've only worked with aero ports in the past. :P
Edited by Audiofanaticz
No VS threads, I removed your question about which woofer is better.
I would change the name on the thread if I were you just lettin you know
YEEEEEEEEEEEEE
Oh No and Fi also
Edited by FeArZ
2009 Tahoe
2000bc Cresendo POWA Need 3500
2 Sundown Zv3 18 high rolled sexiness
dual alt bracket with Singer alt(coming soon)
Mtx Q(not sure if I'm going to use)
Knu wire and RCA's
Bass Head Bands
Oh and a few pairs of Jordan's
This thread will be out soon so decide what will you be using and post a build thread, from there I can calculate your box or you can use the Torres calculator, My vote goes to Fi easily from those two.
Got a build thread up, and sorry about this thread being against the rules :/. But I will pm you the dimensions if that's ok with you. I appreciate the help guys.
I'm pretty sure there's a "edit post" type thing I'm on mobile so not to sure at the moment
YEEEEEEEEEEEEE
