RAM_Designs Posted January 24, 2012 Report Share Posted January 24, 2012 (edited) Stay within this range and you'll be fine. But you may not have the room to do this. Volume: ~7ft^3 Port area: 90-100in^2 Tuning: 30-33hz Edited January 24, 2012 by RAM_Designs Quote Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011... Link to comment Share on other sites More sharing options...
AI James Posted January 24, 2012 Report Share Posted January 24, 2012 Here is a design suggestion: Enclosure Specifications: Fb = 30 Hz Vb = 8 ft^3 Subwoofer Mounting = Flush Mounted External Height = 20 in External Width = 27,54 in External Depth = 38 in Port Width = 5 1/2 in Cut List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 27 9/16 x 20 Left & Right Sides = 35 3/4 x 18 1/2 Top & Bottom = 27 9/16 x 35 3/4 L Port Internal Assembly Parts: Front to Back = 25 1/2 x 18 1/2 A fair amount of bracing should be added though. probably not going to work since his trunk slopes down to 17" Quote Link to comment Share on other sites More sharing options...
Joe X Posted January 24, 2012 Report Share Posted January 24, 2012 (edited) Right, not using his full depth though. So taking away some more depth hopefully it will fit: Enclosure Specifications: Fb = 30 Hz Vb = 7 ft^3 Subwoofer Mounting = Flush Mounted External Height = 20 in External Width = 32,67 in External Depth = 30 in Port Width = 5 1/4 in Cut List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 32 11/16 x 20 Left & Right Sides = 27 3/4 x 18 1/2 Top & Bottom = 32 11/16 x 27 3/4 L Port Internal Assembly Parts: Front to Back = 22 1/2 x 18 1/2 Extension = 3/4 x 18 1/2 Edited January 24, 2012 by Joe X Quote Link to comment Share on other sites More sharing options...
qcbangin Posted January 24, 2012 Author Report Share Posted January 24, 2012 thanks alot i really appreciate the help. my trunk is weird shaped and that leaves less options for designs. i'm going to do a test fit with some scrap wood and see if it will fit. Quote Link to comment Share on other sites More sharing options...
Joe X Posted January 24, 2012 Report Share Posted January 24, 2012 thanks alot i really appreciate the help. my trunk is weird shaped and that leaves less options for designs. i'm going to do a test fit with some scrap wood and see if it will fit. I can change keep changing dims, Hope you can fit a big enough right angled box as those are the easiest to build. Quote Link to comment Share on other sites More sharing options...
