No. I am going to soon. I just need to find what I want to do with the box. I was going to do a wall but my dad said no. :(
Apparently you didnt do it in the right car then. Cause it works extremely well in open backed cars, such as SUVs. I did it in my SUV and it hits pretty hard. Its the the best set up for a trunk
P.S. my sig is my old box
what? SUV's and trunks are two COMPLETELY different environments. best/easiest setup for a trunk is usually port back sub back. unless you want to take the time to seal everything off, then you would do port forward sub forward. gets louder.
Can you seal it off with subs up port forward?
Save yourself the time and do not do subs up....it is the worst...i went that route first and then found out both forward or backward sounded way better,
Design like a v-shaped box facing forward or backward....
He has a trunk car, not an open-back car.
Subs back port back is best in them unless you seal it, which he could probably do if he made a v-shaped forward facing box.
Hammerdown... 1%
subs side/port back is a great option if you go that route, but i have to agree with just going with 2 12´s on a kick ass box :)
  • Who's Online   0 Members, 0 Anonymous, 1830 Guests (See full list)
