momofx76 Posted January 23, 2012 Report Posted January 23, 2012 I just updated my stereo system in my XB and I noticed that my in-car voltage meter drops to 11.9V at about 70% bass volume WHILE driving (rpms at approx. 2000rpm is when I noticed it). I already have a 15 Farad Stinger Cap installed so do you guys think I should install a bigger Cap or ditch the whole cap idea and just get a bigger alternator?
Miguels Posted January 23, 2012 Report Posted January 23, 2012 get an alternator and ditch the cap for a battery my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
stinky feet Posted January 23, 2012 Report Posted January 23, 2012 ditch the cap and add ether a battery or a new alternator. If you have the cash i would go with an alternator.
412 CVX Posted January 23, 2012 Report Posted January 23, 2012 alternator Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
Guest Posted January 23, 2012 Report Posted January 23, 2012 ditch the cap and add ether a battery or a new alternator. If you have the cash i would go with an alternator. its not either. he NEEDS a new alt AND a big battery if his voltage is dropping into the 11's. and yeah, sell the cap and you have some money for a new alt.
stinky feet Posted January 23, 2012 Report Posted January 23, 2012 ditch the cap and add ether a battery or a new alternator. If you have the cash i would go with an alternator. its not either. he NEEDS a new alt AND a big battery if his voltage is dropping into the 11's. and yeah, sell the cap and you have some money for a new alt. I meant adding a battery in the back of the car
momofx76 Posted January 23, 2012 Author Report Posted January 23, 2012 Ok I think I will go with a deep cycle up front and a 250A Alternator (oem is 100A). Should be enough for my setup! Thanks.
momofx76 Posted April 3, 2012 Author Report Posted April 3, 2012 UPDATE : I found this very hard to believe buuuut, the culprit of the voltage drop, headlight dimming alot, etc. was a damn Tsunami 140A breaker that I used instead of the regular big fuse! I discovered this by mistake lol and my small system is running like a champ now! The headlight still dim but very slightly - a day and night difference compared to how it use to be! I will never ever use an electronic breaker again!!!!
