'84 F250 door panel "build"
So I'm keeping my old man's old truck, & as a 30 year old truck, I thought I'd give it few new school touches since I've got gallons & gallons of fg resin just sitting in my lil "backyard".
First was making the door panels from the stock 2-piece to one whole panel by fiberglassing a piece of 1/8 mdf to the bottom half of the panel, onto the pics:
This is how the originally were..
After glassin' the panel came these to hold the speaker ring..
Sticks held in place with hot glue..
speaker ring in place ready for fleece.
Fleece resinned up.
AND, as always reppin' SMD!
That's all I got for today, hoping to finish them up by the end of the week in my spare time.
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
Cool man, these early model Fords are very solid trucks! Well when I get the funds I'm planning on replacing the stock 70amp alt with 2 or 3 H.O. alts sine the engine bay has lots of extra room. For some reason my truck's headlights dim(flash) when at idle, so my electrical is real weak right now. Probably just needs a new voltage regulator.
What engine does your truck have?
Yeah my 71 has factory wiring still so its in need of a upgrade for real. you can try this for wire upgrade http://www.painlessw...talog/index.php . Theres a lot cheaper though from some of the ford forums ive been on.
Thanks for the link man, this truck is in real need of new wires, the previous owners chopped some wires & tapped into other wires leading into the fusebox, but surprisingly everything still works.shrug.gif
Got started on the driver's side panel today, not much done since it was too cold to glass, but it's some progress:
holes drilled into the plastic so that the resin can "rivet" itself & not come off the panel.
Everything on the panel will be filled in & "shaved".
Tuned in :popcorn:
03' NISSAN XTERRA
(1) AQ3500d
(1) AQ4x90
(1) Audio Control Line Driver
(4) DC LVL 4 15's
Cresendo Mids and Highs
100' of 0/guage
Big Three
Mechman 270a Charging @ 16.5v
(6) XS D1400's
Highest Termlab Score 149.9 at the kick & 166.1 in the Port/ on stock electrical and 1 DC XL M1
Updated JUNE 2012*****MY BUILD LOG
USACI REGION 6 POINTS LEADER 2011
USACI KANSAS RECORD HOLDER 2011
Team DC
http://www.dcsoundlab.com/
maybe you should save it instead
  • Who's Online   1 Member, 0 Anonymous, 1216 Guests (See full list)
