low voltage problem
I only had D3100 for couple of months in my car. So what you saying is my battery got damaged along with an alternator?
Yesterday, my voltage went up to 13.9, but doesn't go to 14v anymore.
Youre battery could be damaged, by not maintaining a certain voltage the batteries cells can begin to die. Your battery needs to be put on a charger as soon as possible to prevent any damage to the battery. If your battery voltage drops that low after the charge then you may be looking at a dead/damaged cell
you win some, you lose some
i doubt they could have damaged it any worse than you did in the two days. but its why i pull fuses before any work is done.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Little update
Checked the charging voltage upfront and it came out to be 14v, so is in the back. However, the battery is sitting @ 12.5v. So I took it out and put it on the charger.
I did little test where I turned the car on and disconnected the battery. Voltage was slowly dropping below 13v.
Now, I put my kinetik hc1800 in for now and even with good battery it's around 12.2v with car off and key turned to first click.
  • Who's Online   0 Members, 1 Anonymous, 1079 Guests (See full list)
