lolitskasey Posted January 24, 2012 Report Posted January 24, 2012 So i am looking for a good 2 channel LOC that will work with some what of a high watt syetem, with the car that i have i can not use a aftermarket radio so i have to use a LOC. I was looking at the Audio Control LC2i 2-channel, but it says 400 watt handling... i will defiantly be using more then 400 watts. Thanks, Kasey Quote
evermaxx Posted January 24, 2012 Report Posted January 24, 2012 If you are using more, buy a aftermarket stereo.. And if your using what is in your signature you aren't going to get no where the max out of that system with a LOC. They don't give out enough volts. Quote Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
IBleedMusick Posted January 24, 2012 Report Posted January 24, 2012 If you are using more, buy a aftermarket stereo.. And if your using what is in your signature you aren't going to get no where the max out of that system with a LOC. They don't give out enough volts. I don't think he can. OP what year make and model is your whip. We have had a few cars where you can't change the stock HU or it is more expensive to change it than anything. One car we did recently was a Taurus I believe so we just relocated the aftermarket HU to the glove compartment and left the stock HU alone. Quote 2013 Dodge Charger Build Log 1996 Ford Explorer XLT 5.0Build Log 2005 Honda Civic LX Coupe Build Log SMD SUPER SELLER!!!!My Selling Feedback
fueledbysound Posted January 24, 2012 Report Posted January 24, 2012 So i am looking for a good 2 channel LOC that will work with some what of a high watt syetem, with the car that i have i can not use a aftermarket radio so i have to use a LOC. I was looking at the Audio Control LC2i 2-channel, but it says 400 watt handling... i will defiantly be using more then 400 watts. Thanks, Kasey Your factory stereo puts out more than 400 watts??? That is one HELL of a factory stereo! Quote Daewoo Leganza with Commodore 64 installed in the dash.
lolitskasey Posted January 24, 2012 Author Report Posted January 24, 2012 See the problem is my car has fiber optics not analog like normal cars. So it put a aftermarket radio I would have to gut everything out of my car and put whole new speakers and amp in. I own a 2006 BMW 325 with the logic 7 sound system. Quote
lolitskasey Posted January 24, 2012 Author Report Posted January 24, 2012 I am talking about amp watts.... I will be using a lot more than 400 watts via amp power. Quote
bre2ts Posted January 24, 2012 Report Posted January 24, 2012 See the problem is my car has fiber optics not analog like normal cars. So it put a aftermarket radio I would have to gut everything out of my car and put whole new speakers and amp in. I own a 2006 BMW 325 with the logic 7 sound system. The rf 360.2 can do factory integration Quote Feedback 1 | Feedback 2 you win some, you lose some
lolitskasey Posted January 24, 2012 Author Report Posted January 24, 2012 The rf 360.2 can do factory integration will it handle let's say 7k watts.... That is all I am asking if a loc work with a high powered system. Quote
fueledbysound Posted January 24, 2012 Report Posted January 24, 2012 FYI, the watts that the interface can handle is referring to the OUTPUT of the head unit (or factory amp in your case) that are connected to the high level inputs of the device. It has nothing to do with how much power you are running downstream of the RCA outputs of the LOC. The Audio Control DQL-8 will do the job. Quote Daewoo Leganza with Commodore 64 installed in the dash.
lolitskasey Posted January 24, 2012 Author Report Posted January 24, 2012 That is what I thought, I was just double checking. I think I am going to go with the lc2i Quote
