ok so got all the wood cut for the kicker l5 box, just not sure weather to use just glue, i can use a staple gun its just im scared of splitting the wood, will wood glue be strong enough or should i screw it/ staple it??
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
2 15s 4inch coil psi recones temp til my subs are reconed
Focal P165-v15
Audison voce quattro
fully active
Only gonna get louder
146.1 at 38hz
138.x at 24hz
Build log
http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/
Why would you use a staple? Use titebond 2 or 3 wood glue and screws.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
im wit fizzy on this one. i would never just use staples or screws. actually i wouldnt use staples at all. use wood glue and screws.
C-Fizzy, on 01 April 2012 - 01:06 PM, said:
Clip city bitch, clip clip city bitch. 10's, 12's, 15's, goin up in flames bitch.
Check out my build thread http://www.stevemead...product-page-2/
New build
http://www.stevemeadedesigns.com/board/topic/172646-punkrocks-97-civic-build/
ok, should i screw it after, cause im woried about cracking the wood
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
Dry fit the box (no glue) pre drill holes. Glue sides one at a time, clamp the together then fill in predrilled holes with screws.
under construction
u hate c-fizzy?
Yep,if you pre drill then you won't get any splits
Posted (edited)
is it alright to pre drill after the glue drys?
Edited by WadeTustian
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
I would pre drill before you do any glueing. And do you know what predrilling is? Find a drill bit a little smaller than the screws you're using. Drill with those. Then use the screws.
under construction
u hate c-fizzy?
Posted (edited)
this is the order you do it in
pre dill, glue, screw. then for all the inside corners you should put a sealent to make sure its air tight.
to pre drill the hole you need to line the wood up how it will be when its done then drill the holes. i suggest doing one in each coner first and then putting in a screw so that the box cant move or shift while drilling.
take the screws in the corners out then use wood glue to put the box together. do one side at a time and screw the boards together so that it will apply preasure to the glue so that it gets a good strong hold and hopefully fill in any air gaps.
as you put the box together you will want to put some sealent ( i use liquid nails ) in the corners so that any slight air hole can be filled/covered so that there is no chance of air leaks.
let it all dry overnight, the next morning clean off any extra glue from the outside of the box. take some wood glue and sawdust mix it together and use this on top of the screw heads to cover them. then as your choice cover the box in fabric or paint it. you can also paint and upholster the the box.
FYI if the box is ported your should also atleast roung off all the edges of the port walls inside and out. better air flow
Edited by alaskanzx5
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Posted (edited)
What size do you recommend for screws and pre drilling bit size?, should i make the middle part first and then pre drill the bottom after i glue all the middle together
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
  • Who's Online   0 Members, 0 Anonymous, 590 Guests (See full list)
