Relyks Posted January 28, 2012 Author Report Share Posted January 28, 2012 how far from the back wall does my port need to be? Quote --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12 Link to comment Share on other sites More sharing options...
CaPRiCEx383 Posted January 28, 2012 Report Share Posted January 28, 2012 If its on the left or right side, It needs to be the same size as the width away. If in the middle, Half of the width going both ways. Quote 90 Nissan 240sx Avic z-140bh Audison SR4 Audison Voce 6.5s CDT es-20 tweeters Sundown 1500v3 (2) DD 9510's 3 cube box 2 6" aeros XS Power D2400 & Xp950 Skyhigh/Knukonceptz/Rockford Fosgate wiring More Coming Soon.. Check my builds below. 97 Civic Hatch Build 86 Caprice Build you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion Link to comment Share on other sites More sharing options...
pa-pa-platypus Posted January 28, 2012 Report Share Posted January 28, 2012 the width of the port..if longer than make a bend Quote This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4 Link to comment Share on other sites More sharing options...
Relyks Posted January 28, 2012 Author Report Share Posted January 28, 2012 AQ 1200.1 D is the ONLY Amp i have ever owned also i went from 1.5 cu.ft on a single 10" sd 2.5 sub at 35hz to 2.00cu.ft at 35hz and it was way better. completely only thing in the set up that changed was the box not the port placement sub placement or type of port only thing that change was cu.ft and Ken at AQ , AMICustoms , Dan and few other people recommended 35-38hz an .5 cu.ft more for each sub then a normal 12" cause of the fact that they like more air and they like being tuned in that area. ye si have tested it yes they o like more air. Quote --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12 Link to comment Share on other sites More sharing options...
Relyks Posted January 28, 2012 Author Report Share Posted January 28, 2012 take double baffle out of the equation. not happening Quote --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12 Link to comment Share on other sites More sharing options...
CaPRiCEx383 Posted January 28, 2012 Report Share Posted January 28, 2012 That looks better, Common port walls should be 3. Is there anyway you can get more port though? If not that will get you by i guess. Quote 90 Nissan 240sx Avic z-140bh Audison SR4 Audison Voce 6.5s CDT es-20 tweeters Sundown 1500v3 (2) DD 9510's 3 cube box 2 6" aeros XS Power D2400 & Xp950 Skyhigh/Knukonceptz/Rockford Fosgate wiring More Coming Soon.. Check my builds below. 97 Civic Hatch Build 86 Caprice Build you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion Link to comment Share on other sites More sharing options...
Relyks Posted January 28, 2012 Author Report Share Posted January 28, 2012 THIS!!!!! Quote --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12 Link to comment Share on other sites More sharing options...
jsawdy212 Posted January 28, 2012 Report Share Posted January 28, 2012 (edited) nevermind u changed the port walls Edited January 28, 2012 by jsawdy212 Quote 2007 caliber 2 Fi ssd 18's rd audio 3250 xs power d3100 (need 2 more) stock alt (soon to be singer 350a) 2.75:1 4th order in progress! Link to comment Share on other sites More sharing options...
Relyks Posted January 28, 2012 Author Report Share Posted January 28, 2012 And explain 3 common port walls to me? not goo at making slow ports... also explain what you meant port is going to be all the way to the left side of the box fired to rear. Quote --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12 Link to comment Share on other sites More sharing options...
jsawdy212 Posted January 28, 2012 Report Share Posted January 28, 2012 3 common port walls means the u use 3 side of the box and add a port wall to make the slot port. Quote 2007 caliber 2 Fi ssd 18's rd audio 3250 xs power d3100 (need 2 more) stock alt (soon to be singer 350a) 2.75:1 4th order in progress! Link to comment Share on other sites More sharing options...
