onelivinlarge Posted June 3, 2010 Report Posted June 3, 2010 will this let my battery charge easyer? sorry for the noob question 1) lookj to left 2) NOTICE BLKUE 3) ME > Y9OU 4) that is all
Rainkey Posted September 3, 2010 Report Posted September 3, 2010 Negative from battery to ground Engine block to ground You can put these in the same place? nooby here
mason313 Posted October 6, 2010 Report Posted October 6, 2010 Will it hurt to run from alt(neg) to batt(neg) or even to body ground? 2 18" fi btls 2 sprinter batts 165ah 1 cresenscdo 3k 1 mechman 270a 1 kinetik 2000 under hood
mako22 Posted November 12, 2010 Report Posted November 12, 2010 thanx alot....but how does this help the battery and amp? I'm alil lost..
Purplehaze Posted January 29, 2011 Report Posted January 29, 2011 does anyone use circuit brakers???? just wondering dont see many ppl using them. i use 300amp circuit brakers.... for my A.B. VFL 200.1 also. just wondering if anyone else does. nope. and there is a very good reason why you dont want to use one. - every time that breakers goes off it degrades and that choice of protection is being less and less reliable every time it goes off. - a fuse thermally burns up when it has surpassed its limit so you can deem it more reliable than a breaker to do so. a fuse will be more reliable than a breaker, i rather spend a few a bucks more to keep a stash of extra fuses then to have a breaker that may or may not work when needed Actually, I believe it's a matter of opinion. I use breakers, and have no problems. If you use quality breakers, they will work fine. A fuse can malfunction and cause fire just the same. And if you think about it, Industrial Electricians stopped using fuses in houses and businesses years ago, everything is now breakers. And that is AC. If they work in my house, why not in my car? Also, I noticed that Steve used them on the Escalade. Kickin' Cruiser Seller Feedback Stage 3 Dash, Door Panels,4th Order wall 4 - 15'son a DC 5.0K 2 DC 5.0K'sSolo X 15 (v.2) Sub Build
Babyjuice Posted January 31, 2011 Report Posted January 31, 2011 so does the awg matter? i want to do this on my 03 f250 that is powering a kenwood kac8104d and soon a hfi1000d so will 4awg be good enough? thats what i have for my power wire to amp. BABYJUICE
Foxracer27 Posted March 19, 2011 Report Posted March 19, 2011 parts express What size did you get? 3/8?
Gotloud555 Posted April 5, 2011 Report Posted April 5, 2011 thanx alot....but how does this help the battery and amp? I'm alil lost.. Put less resistance on the electrical.
ionsmartparts Posted April 14, 2011 Report Posted April 14, 2011 Hey i put my block to chassis ground and ran it from my alt mount to my negative terminal. does this still work fine. -2002 Impala Ls -Optima yellow top x 2, big 3 -Pioneer 5.8" touchscreen -Infinity 6.1 Kappa Perfect Components -Alpine type r 6" coaxial x 4 - Audio Que hdc312 x 2 -Mb quart 4 ch. x 2 -knu wire -Audio Que 2200w amp - db electric 220amp alt
