wheres the flex at Posted January 30, 2012 Report Posted January 30, 2012 Okay I've got rid of my 4 gauge and bought some Stinger 1/0, the area where I had the 4 gauge running was already tight and I can't get the 1/0 through there. My question is would it be a good idea to run it under the truck and secure it with insulated metal hose clamps, or to drill a hole in the firewall and buy one of them Stinger Firewall gromments? ANy help would be greatly appreciated. 2001 Nissan Frontier3/5 drop ''Gutted" Underconstruction If you don't let your unborn swim in her mouth someone else will.
BFF Larry Posted January 30, 2012 Report Posted January 30, 2012 which every would be easier for you to do, would be the best bey. if you run it underneath the truck, get some pvc pipes and run it along the frame of the truck. just make sure its out of the way so that you can still put the truck on a lift. use a larger diameter pvc pipe so that you can run more 1/0 in the future. Team Clearly Louder (MECA)Team DC Audio ++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++ HMU!!! 3 flips. nollie flips. big flips. hardflips. - steez Youtube Channel My Build Log 95 Bonneville SSE - WALLED/4th Order - ~30 cubes - *thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
n8ball2013 Posted January 30, 2012 Report Posted January 30, 2012 i run underneath in the frame rail. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Blackedout Posted January 30, 2012 Report Posted January 30, 2012 Doesn't matter which way you go about it as long as you do it correctly... Using grommets where grommets are needed and not crossing obstacles (hot exhausts, sharp objects, etc) that could lead to a short down the road. Trunk Build Log
bre2ts Posted January 30, 2012 Report Posted January 30, 2012 Plenty of people including myself run wires beneath the vehicle. Just make sure it's secure and away from moving parts and the exhaust. Feedback 1 | Feedback 2 you win some, you lose some
Blackedout Posted January 30, 2012 Report Posted January 30, 2012 To add to my post I ran mine down the unibody in PVC tubing. My build thread is in my signature if your looking for ideas on what I consider to be done right. Almost 2 years later with no issues. Trunk Build Log
wheres the flex at Posted January 30, 2012 Author Report Posted January 30, 2012 Thanks guys, That was a lot quicker than I anticipated a answer. So Pvc is it. I"ll see how that goes 2001 Nissan Frontier3/5 drop ''Gutted" Underconstruction If you don't let your unborn swim in her mouth someone else will.
wheres the flex at Posted January 30, 2012 Author Report Posted January 30, 2012 Blackedout, I'm checking your build out and I like the way you put everything together. 2001 Nissan Frontier3/5 drop ''Gutted" Underconstruction If you don't let your unborn swim in her mouth someone else will.
