porksoda Posted January 31, 2012 Report Posted January 31, 2012 Well I have a daily driver that has a couple blown factory speakers in it. The car all factory speakers in it now. I plan on just replacing the speakers with Coaxial speakers because they are cheaper and this car is just a beater. The car takes 5.25 speakers in all the door and back hatch. The speakers I came across are SoundStorm LS52 . I will be powering the speakers off the Head unit itself. The headunit is a Kenwood KDC-138. I could order 2 pairs of them for $28 shipped. So that will do all 4 doors. I am sure they will be better then my blown factory speakers but I just want some peoples opinions. The car by the way is a 1993 Dodge Shadow ES. SoundStorm LS52 Poly-coated paper cone Santoprene surround High temperature aluminum voice coil Mylar dome tweeter Peak power handling: 250W Magnet structure: 25 Oz. Efficiency: 90dB (1 Watt/1 Meter) Impedance: 4 ohm Frequency response: 85Hz-20kHz Mounting depth: 1-15/16" Car speakers are usually sold as a pair unless otherwise noted. UPC: 791489000000 Weight: 3.42 Well thanks for all your advice in advance. My truck build: http://www.stevemeadedesigns.com/board/topic/111744-1998-dodge-dakota-build/page__pid__1565536#entry1565536 AlphaDamp CLD Mats - Get more sound deadening using less sound deadener
porksoda Posted January 31, 2012 Author Report Posted January 31, 2012 I forgot to add a link to the product: http://www.onlinecarstereo.com/CarAudio/p_25611_SoundStorm_LS52.aspx My truck build: http://www.stevemeadedesigns.com/board/topic/111744-1998-dodge-dakota-build/page__pid__1565536#entry1565536 AlphaDamp CLD Mats - Get more sound deadening using less sound deadener
KillaCam Posted January 31, 2012 Report Posted January 31, 2012 Eh, you get what you pay for. But I guess if your speakers are blown and its just a "beater" then I guess they'll do. Just don't expect them to sound amazing, or even good. And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log
POPLERO Posted January 31, 2012 Report Posted January 31, 2012 I would probably say maybe even less quality than the oem ones.. 2008 TBSS Black Granite Alpine CDA-117 Clarion EQS746 AudioQue Supertweets @ dash Alpine DDT-s30 @ b pillars Alpine SPR-60c @ front doors Alpine SPR-60 @ rear doors Alpine PDX-f4 Second Skin DampPro KNUkonceptz Wiring DCpower 270amp alt Optima YT underhood *temp Two15DCxls Hifonics bxi2610 *temp saz4500 and 4 xp3000s coming soon.
Skullz Posted January 31, 2012 Report Posted January 31, 2012 I tried going that route once with a car and was no where near happy with how horrible it sounded, just get some decent speakers for it cause you can always take them back out if you sell the car. http://www.sonicelectronix.com/item_19558_Rockford-Fosgate-Punch-P152.html 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
