Little Box help
ehckz
I bought 3 hdc3 10"s to replace my 3 12" type Rs because they should fit a little better.
I'm wanting a subs forward, port forward box, sealed off of course. Each sub will be getting approx. 1000 watts.
Dimensions are 13.5h 39w 26d
If I go with a slot port it needs to be about 12h by 5w to get it in the port range, but that is going to leave the subs all pretty close together and then 1 will be realllyyy close to the port wall and the other close to the outer wall. Whereas it could possibly be a better fit if i went 4 4" aero ports or maybe some other size and what not.
So basically would the slot port style work or should I look into figuring something out using aero ports?
Build In Progress for Slamology 2013
3 m1xl 18s walled in a gti
1 5k
4 batts
audio technix 1/0
8 cheap r/f 6.5s
mb quart 4.60
What about something like this:
That is a good design. Would the sub sitting so close to the port wall be a problem? And how much would that slant take off of the box volume? I want to get around 4cub ft after the port/displacement/bracing
1 5k
4 batts
audio technix 1/0
8 cheap r/f 6.5s
mb quart 4.60
You should not notice any ill effects with driver being so close to the port, to the best of my knowledge anyway.
The volume that the slant consumes is fairly significant, at about 1333 cubic inches. You would also need to be concerned about the left driver's motor hitting the inside of the left wall. I am unsure of the depth and motor diameter so I was unable to take that into account at the time of the drawing.
Your right, it might be a little close. Depth is around 7.7" and I would say the motor is a good 8.5" wide, flush mounting 1 in a temp box was a pain in the ass.
1 5k
4 batts
audio technix 1/0
8 cheap r/f 6.5s
mb quart 4.60
I have seen subs damn near on top of the port wall...not sure if it matters or not
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
You can do this also with four 4" aeros if you find a nice way to fit them so try putting them around the center subwoofer, here is a design suggestion that uses a double layer baffle:
Enclosure Specifications:
Fb = 36,097 Hz
Vb = 4,849 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 13,5 in
External Width = 39 in
External Depth = 25 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 39 x 13 1/2
Left & Right Sides = 22 3/4 x 12
Top & Bottom = 39 x 22 3/4
Port Quantity and Dimensions:
Number of Ports = 4
Aero Port Diameter = 4
Aero Port Length = 18 1/2
  • Who's Online   0 Members, 0 Anonymous, 1786 Guests (See full list)
