my original idea was to go with an 18" FI SSD, and keep my power acoustik amp.
my new idea is to go with a Audioque HDC318 and power it with a AQ1200D.
my theory is this: the AQ amp says its stable down to 1ohm. i noticed two speaker inputs on the amp. so, my idea was to go with a dual1 with the sub, and wire each coil into each speaker terminal.
OR....should i get a dual2, wire it down to 1ohm, and use only one of the speaker terminals?
keeping in mind that budget is a factor, tax return money will free up some, but this is why i picked these combo's. trying to get rid of the cheapy stuff.
1992 Camry "Stormtrooper"Quantum Audio DVD/USB/AUX 3.5" single din H/UXS D690Cadence 0g wiring and Kicker 4g wiring(2) Selenium 6w4p's(2) Selenium ST200'sKicker 200.4 (mids & highs)(1)Kicker and (2)Stinger RCA'sSecondSkin in trunk and doors12K HIDsMulitcolor Angel EyesSoon to be done:Big 3Mechman H/O Altsubs?amp?
That thing is going to eat people nearby cars, unsecured objects, and small children
Fixed!
wow nice. i wanted nos on my car but the gf said no. i was just gunna do a 50 shot tho haha
Get a new girlfriend.
amp is a mono, the two sets of terminals are there for ease of wiring, itll be like you wired down to 1ohm, if you did each coil to each set of terminals on the amp....im pretty sure im right, but i could be wrong, anyone wanna varify?
edit, dual 1's will go to .5 if you do what i said above..
i really cant read thoroughly tonite
Edited by Freshman6969
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
like said, it has 2 sets of 8 ga inputs so if there is multiple subs on 1 amp, you are not jamming 2 wires into a single input (ease of wiring). with 1 sub just use 1 pos and 1 neg and you will be fine.
Edited by ChevyBoy95
it looked like a mono to me, thats why i was slightly confused on why it had two speaker terminals. looks like ill lean to the dual2
Fixed!
Yeah go dual 2. There's no need to wire at .5 for daily.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
yeah, def no need for .5 for me. thats why i wanted to stick to 1. figured i would ask here, before i went and made a :noob: mistake. plus, with my headache right now, im not thinking straight lol
Fixed!
hey meow, i run .5 daily :pardon:
basically meaning that if i got a dual 1, and wire each coil into each speaker terminal, then the amp would be seeing a .5 load?
Edited by Kdub26
Fixed!
  • Who's Online   0 Members, 0 Anonymous, 2096 Guests (See full list)
