Once you do the big 3 and the new battery you'll know if you need another battery but i would hold off till then and see how it goes.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
nah youll be fine with an upgraded front battery and the big 3 with that amp..ran an aq 1200 (similar current draw) upgraded front batt and big 3 never drop below 13 volts full tilt at idle.. BUT just in case..whats the size of ur stock alt though?
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
The big 3 would be fine. If after you do that and you notice a drop in volts. Thats when you would know you need another battery.
Current system (still building) 2 kicker 12" dcvr in factory kicker ported box, Rockford Fosgate 1200.1 Amp, Kenwood ddx-470 ddin radio, Rockford Fosgate 0 Gauge wiring, Rockford Fosgate punch 6X8 2 way speakers.
What are you putting it in? My 03 focus se has a 110amp stock. I added a 220 amp svt focus alt and 2 audio batteries for 2 kenwood performance series 1,800 watt amps. Works fine for it.
  • Who's Online   0 Members, 0 Anonymous, 456 Guests (See full list)
