Tweeter help
KenC210
so i got a pair of CADENCE ZRS-40T specs are below. The question is what would happen if i send them a signal at 200hz and above? Would the in line 12db crossover cancel out the rest of the freq? Would like to know cuz my amps Variable high-pass filter is 50-200 Hz, 12 dB/octave
Cadence ZRS-40T 1" SILK SOFT DOME TWEETER
Complete with flush, surface, and angle mount hardware
Ferro-Fluid Cooled Voice coil
High Temperature ABS housing
1.2" HiFi 4 Ohm Tweeters
RMS Power: 110 Watts
Peak Power: 220 Watts
Frequency Response: 1.2KHz-25KHz
Sensitivity: 94db @ 1W/1M
Mounting Depth: 7/8"
Dome Type: Silk
Magnet Structure: Neodymium
Titanium dome
Flush/Angle/Surface Mountable
In-Line 12db Crossover
Mounting Hardware Included
New and improved design
Rear Bullt Housing
If your using an inline filter then just turn the amps crossover to full range and the inline will filter everything below a certain range.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Yep, what he said
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
ok thats what i thought just needed re-assurance. so if the sound stops out the tweeters i should check the inline filter first to see if it popped and in most cases i could replace it with a new one and it be good?
  • Who's Online   0 Members, 0 Anonymous, 867 Guests (See full list)
