They used to list them, found them in two different loactions around the internet:
XL 12"
Mounting Depth 7"
Mounting Hole Diameter 11"
Motor Width 8.75"
Weight 54lbs
VC Diameter 3" Flat 8 layer
Displacement .19³ ft
Magnet Weight 50lbs
Power Handling RMS/Peak 1500/3000
Impedance (Ohm) d.7, d1, d1.4, d2
Sd 494.00 cm²
Fs 38.90Hz
Qms 6.51
Qes .31
Qts .29
Xmax 26mm
Sensitivity 90.73
Suggested Sealed N/A
Suggested Ported 1.5³ ft
Vas can be "calculated" by formulas and it gave me: 1.456 cu.ft
If not here's how measure Vas (and the other parameters):
http://sound.westhost.com/tsp.htm
Edited by Joe X
Found the T/S Specs for my subs.
15"
Mounting Depth
8.25"
14"
Motor Width
8.75"
Weight
54lbs
VC Diameter
3" Flat 8 layer
Displacement
.23³ ft
Magnet Weight
50lbs
1500/3000
Impedance (Ohm)
d.7, d1, d1.4, d2
Sd
791.00 cm²
Fs
35.60Hz
Qms
6.98
Qes
.32
Qts
.30
Xmax
26mm
Sensitivity
93.70
Suggested Sealed
N/A
Suggested Ported
3.5³ ft
Edited by OBI
15"
Mounting Depth
8.25"
14"
Motor Width
8.75"
Weight
54lbs
VC Diameter
3" Flat 8 layer
Displacement
.23³ ft
Magnet Weight
50lbs
1500/3000
Impedance (Ohm)
d.7, d1, d1.4, d2
Sd
791.00 cm²
Fs
35.60Hz
Qms
6.98
Qes
.32
Qts
.30
Xmax
26mm
Sensitivity
93.70
Suggested Sealed
N/A
Suggested Ported
3.5³ ft
And in case you didn't read up there you are missing Vas. Calculated Vas for you but the best way is measure it, and the device suggested can't do it.
Did you use suggest box specs giving by dc for Vas?
Vas belongs to the subwoofer, you use Vas for designing the box, I calculated it from the other parameters but better measure it. Also left you a link with 2 independent methods to measure Vas.
Edited by Joe X
Be careful, DC has all new lines out as M2 versions, all the older ones are M1, so make sure you find the right one to match the sub that you have. GL!
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
  • Who's Online   0 Members, 0 Anonymous, 2702 Guests (See full list)
